2s battery charger
Maverick923
Joined Feb 4, 2019
14
Hello folks, I am looking to supply power for a device. I want to use, 2x18650 cells. I was looking for something that will protect, supply power and balance charge at 2 to 3A. I am going to use a USB type C power adapter to power and charge at the same time.
Not only that, but I am also looking for thermal sensing where the charging current can be lowered should the cells become too hot.
I was looking at the modules from AliExpress, but many seem to lack the features I am looking for. I started to look into making my own, but I am no engineer. Furthermore, I am trying to make sense of it all, and I thought it would be best to consult with someone.
I was thinking of going with the BQ25713. I am not sure how would I plan this circuit specifically. I would like to have a PCB made, but I have never done that either. I would really appreciate some help or a better solution.
https://www.ti.com/lit/ds/symlink/bq25713.pdf?ts=1723281095838&ref_url=https%3A%2F%2Fwww.ti.com%2Fproduct%2FBQ25713%3Fbm-verify%3DAAQAAAAJ_____wWYbT4FCoTfJFf9qN9zqG0swbmtEysd9_AEI5PhcTsjIGpYUgfjaxGJinQVPyvIjc9db_DAoPbTYSjc23oEFz0UN0jLW2DZumORwOOlHGNV7kUDTCrmde8TAgCRit1Yy-Zm9gezBzVPfX0UoKnfD6h3KOUu_x0lFXPtWezsUGAa1UAML9tM9DfoFsXwtTdczJ9Dz49rmXKsgFStvOpkBVje9Txy09PVo38OPP5l4A0NfuAx0_tqhmQoArjbr2FZUl_Qc4dhKwEbqwfd-4jOOW_cRnoHVv0zFFvMSLTwOf9p
LowQCab
Joined Nov 6, 2012
5,101
Modern USB-3 High-Current-Charging is too complex for a first-time-Project.
There are far too many ways that You can get it wrong and smoke-parts or even start a fire.
If You want to put the Cells in parallel,
and Charge them with a USB-2 interface at a max of 1-Amp,
that's a much more realistic first Project.
