2N7000 strange behaviour
igeorge
Joined Jul 2, 2010
60
I want to use a 2N7000 as a switch to protect my circuit for over voltage.
I have a scenario when i feed 5 volts and everything should be fine.
But is i feed 24vdc the fet should start conducting and blow the fuse.
On data sheet of 2N7000 trigger si 0.8 to 3 vdc.
I attached 2 pictures which should explain better.
Even if i make GS 1.92 volts, the fet stay open and the fuse does not blow.
I need help as it is first time when i work with Mosfets.
kubeek
Joined Sep 20, 2005
5,796
If you want anything even remotely close to precise, you can´t rely on the mosfets Vgs threshold. Use at least a bipolar transistor to trigger it, or even better a tl431.
38,503
The behavior is not strange at all.
Your answer is right there.
0.8 to 3V for Vgs means that's the manufacturing range of Vgs(th).
A particular device can be anywhere between those two voltages and even at that voltage, it's only conducting less than a mA.
Below is the LTspice simulation of a circuit using a 9.1V Zener, D1 to turn on the MOSFET starting at about 11V.
The blowing of the fuse is not simulated.
You can use a lower voltage Zener if you want the MOSFET to turn-on starting at a lower voltage.
Edit: Attached is the circuit using a TL431 programmable reverence (zener).
The TL431 starts to conduct when the control-node to anode voltage reaches 2.5V.
Thus with the R1 and R2 resistor values shown, it starts to conduct at a cathode to anode voltage of 1oV nominal (where Vg starts to sharply rise).
