2N4082 Dual J-Fet - N Channel - Jersey semiconductors
spuddo
Joined May 2, 2013
76
Hi , can anyone help with the pinout of the above jfet.
I've googled , but no result.
The person selling these on Ebay had no luck.
Best regards.
spuddo
Joined May 2, 2013
76
Do you have the J-FETs? If so, you should be able to work out the pinout using a multimeter.
Thanks for the reply.
I've ordered them and believe the T0-71 pinout provided by Dennis will be a bottom view and all will be fine.
Still cannot work out why numerous attempts to google a data sheet flopped.
At least i won't die wondering.
Best regards
dl324
Joined Mar 30, 2015
18,296
If that is a bottom view , then the configuration is right for my purpose (replacing a jfet in an old Minimoog oscillator and i prefer to have a straight drop in).
I'd assume it was the bottom view as that's what most datasheets I've seen used. Manufacturers don't seem to be paying to detail as much as they did in the old days...
It would be nice if i could be certain that the diagram shown is that of a 2N4082.
You can have the seller check Idss using the pinout above.
