What is your input voltage? probably not 52 volts.@ronv, thank you.
For the 3.3A application, using two 2N3055 is enough, if the current count LM317 in then 2N3055 is not that much, my power supply(made by Kit) used uA723 and 2N3055x2 (4A), each 2N3055 flows through 2Amax, here if LM317 flows through 300mA then each 2N3055 only flows through 1.5A.
