I have here a 3000 watts transformer from a voltage regulator. I want to make this into a car battery charger.
Can anyone help me how to make this?
Its output voltage is 25v
it is not a center-tapped sir. only two wires of output.If the secondary is on the outside, you could remove winding to lower the voltage.You also might be able to find the center winding and break it out for a center tap. A center taped 25 Vac winding would give you 17 volts unloaded.
What kind of battery charger do you want to build; smart or simple (dumb)?
Unfortunately as I and others have stated the present 25 volt output voltage is way too high to directly charge a 12 volt vehicle battery. You need to get it down to around 11 to 12 volts AC to be workable.it is not a center-tapped sir. only two wires of output.
i like to make it simple charger sir. if i will buy diodes and capacitor can you please give me some codes and voltage ratings of it?
I will reduce its winding sir so that I can get 12v.The transformer, without modification, will work very poorly as a battery charger. The transformer voltage is just too high to charge a 12 volt battery.
Please post some clear and close up photos of the transformer. Perhaps we can assist you to modify the transformer.
ok sir thank you. can i control its current sir?Okay? Someone disappeared from the thread between what is now post 4 and 5?
To charge a vehicle battery you need around 14.5 volts DC which with AC current has a peek voltage 1.414 times higher than its RMS voltage we rate it at. To get a peak voltage of ~14.5 VDC from and AC supply you need to drop the AC voltage down below 12 volts so that the peak voltage and the included voltage drops in your diodes (~.6 -1 volt ) works out to being around 16 volts peak at no load.
So, ((16 - 1.2)/1.414 = 10.5) VAC. Add in the input and output line losses and miss other small voltage losses and a AC input of around 11 volts works really well for a high power 12 volt lead acid battery charger.
So there is what you need. You need to get that 25 volt AC output down to around 11 - 12 volts first.
For diodes any large 100 volt or more rated diodes in the 300 - 500 amp range mounted to a big heatsink would work well.
If you keep the peak DC output voltage under 15 volts physics will take care of the rest.ok sir thank you. can i control its current sir?
like a variable current controller
At roughly 7.5" cubed I would put it at 1000 - 1500 watts continuous capacity myself which if used as a battery charger transformer it's not likely to ever see even that power draw level long enough to do any harm to it.To all: Looking at the photo, is a transformer of that size really > 100A capable? I've had 25V transformers half that size that only did about 1A. I'm wondering if there's something lost in translation here. I imagined a 3KVA transformer to be much bigger.
You need more than 12V to push charge current into a 12V battery.Well, ideally you need to get an output of around 11 -12 volts AC to work for 12 volt batteries.
Does the 25 volt secondary have a center tap or the primary have two windings that can be configured in series to reduce the output by half?
Yes, I know. 11 - 12 VAC RMS has a peak voltage of ~ 15.5 - 16.9 volts.You need more than 12V to push charge current into a 12V battery.
In most charging situations it shouldn't exceed 14.4V.
OK, I see where you're coming from. And that's probably more along the lines of what the TS wants. But it would seem that that particular transformer would have to be tapped at a 12V point in order to make a simple, passive charger as you describe.At roughly 7.5" cubed I would put it at 1000 - 1500 watts continuous capacity myself which if used as a battery charger transformer it's not likely to ever see even that power draw level long enough to do any harm to it.
As for current limiting that just adds more cost and complexity to the design that is largely unneeded and if anything a hindrance when you are in a pinch and need to have maximum charging and cranking amps like when you go out to work and find you left your lights on overnight and your battery is now stone dead.
That's where an overbuilt oversized high amp capable charger shines by being able to yank that dead battery up to a workable level in a minute or two and supply a massive current assist while the engine is cranking on top of that.
Yea hitting your dead battery with 200 - 300+ amps might be hard on it but then again you already ran it down too far to start your engine anyway and you're going to be late for work.
What's avoiding that speeding ticket and getting questioned by your boss worth to you?
To most when they are in that position abusing a battery for another minute or two to get on the road is a no-brainer and cheap price to pay.
Yea. Unless he has a double primary that can be put in series there is no easy way to get the output voltage down into the 11 - 12 volt range without doing a rewind or adding a lot of electronics to it.OK, I see where you're coming from. And that's probably more along the lines of what the TS wants. But it would seem that that particular transformer would have to be tapped at a 12V point in order to make a simple, passive charger as you describe.
