250 KHz ultrasonic waves radiofrequency transmitter and receiver
mit_bme
Joined Sep 8, 2017
5
Hi Guys,
I want to transmit 250 KHz ultrasonic waves using radiofrequency transmitter and receive the data at the receiver.
As a newbie in communication engineering, I dont have much expertees in designing trasmitter and receiver.
Can any one help me with component selection and circuit designing for transmitter and receiver?
35,276
Quite a difference between ultrasonic waves and radio-frequency waves.
Ultrasonics transmit acoustic pressure waves.
RF is electromagnetic waves.
Which one do you want?
mit_bme
Joined Sep 8, 2017
5
Thanks mate for answer.
All I need is, the I need to transmit Ultrasonic waves generated by Piezoelectronic transducer over a distance of 5 meter.
Which kind of electronic circuitery I should use.
Mit
mit_bme
Joined Sep 8, 2017
5
Thanks mate for the answer. I need to transmit data in air. I have looked though HC-SR04 module and the problem with that module is transmitter and receiver are located at the same place. I need modules where i can place transmitter and receiver at a distance.
Any suggestion?
35,276
Next question - What are you trying to do?
You can buy piezoelectric ultrasonic transducers and build the transmitter and receiver circuitry. Acoustic frequency is usually around 40kHz.
Alec_t
Joined Sep 17, 2013
15,160
Why 250kHz? That will be attenuated by the air much more than the usual 40kHz, so would need either a more powerful transmitter or a more sensitive receiver.
k7elp60
Joined Nov 4, 2008
562
Hi Guys,
I think it is very possible to transmit 250KHz thru the air. The navigation system prior to GPS was Loran-c. It's carrier frequency was 100KHz. The range was in hundreds of miles, and sometimes over a thousand miles. I think the most difficult thing to build will be the transmitting antenna. As I think about it, a ferrite rod with a winding on it, could easily be made to resonate at 250KHz.
