I'm designing a power supply to power small electronics via an 24VAC HVAC transformer. I've done a few reading want to think I have the design right. But since this is the first time I'm designing a power supply and not 100% confident with this and want some feedback on anything that can be revised.
The design should be over engineered that should be able to handle 5A each voltage and; so it should be able to handle the 12VDC and 5VDC up to 3A of max current which is my requirement.
List of component:
List of component:
- CONN1 - TERM BLOCK 2POS HORIZ 3.5MM T/H (Wurth Electronics Inc 691103110002)
- D1, D2, D3, D4 - DIODE SCHOTTKY 70V 3A SMC (Diodes Incorporated B370-13-F)
- D5, D6 - DIODE SCHOTTKY 40V 3A SMC (Diodes Incorporated SK34-7-F)
- C1 - CAP ALUM 1000UF 20% 50V RADIAL (Rubycon 50ZLH1000MEFC16X25)
- C2, C3 - CAP ALUM 1000UF 20% 16V RADIAL (Rubycon 16ZLH1000MEFC8X20)
- L1, L2 - FIXED IND 100UH 5A 35 MOHM TH (Wurth Electronics Inc 7447070)
- U1 - IC REG BUCK 12V 3A TO220-5 (Texas Instruments LM2576T-12/NOPB)
- U2 - IC REG BUCK 5V 3A TO220-5 (Texas Instruments LM2576T-5.0/NOPB)
- 2x HEATSINK TO-220 VERT MT BLK 1" (Wakefield-Vette 637-10ABPE)
