24V 15A buck converter suggestion?
ghostmanzero
Joined May 16, 2017
10
Hi everyone I have circuit that i have to power with two different supplies. First one is a 24V(2x12V 3A batteries ) battery and the second one is a 28VAC AC supply. Batteries are OK. No need to change anything. But if it is comes to AC supply, I will use a rectifier but 28VAC will increase to about 40V DC. I need to drive two DC motors with this circuit. So the current will be about 15A. The question is how can I turn 40V DC into 24V (with capacity about 15A) ?
dendad
Joined Feb 20, 2016
4,641
http://www.ebay.com.au/itm/15A-Adjustable-DC-DC-Buck-Converter-8-55V-to-1-35V-Power-Supply-Converter/182619057264?rt=nc&_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=47516&meid=264b7f9fd6bb4367ae6fb692ec53a37f&pid=100005&rk=5&rkt=6&sd=162396525672&_trksid=p2047675.c100005.m1851
Or something like this. Even if you run a couple of lower current versions together.
There are quite a lot on Ebay, just check the input voltage range is high enough. I'd go to higher output current rating if you can get one.
Dodgydave
Joined Jun 22, 2012
11,395
15V @15A is 225W, from a 24V battery you need 20Ah batteries minimum!!!
Mains would be better using at least 10amp supply.
ghostmanzero
Joined May 16, 2017
10
thank you very much :) i have seen these ones before but i want to build my own converter. what kind of regulators i should choose ? what kind of circuit is inside this circut. ? i mean regulator? what is used for the swicthing ?
tcmtech
Joined Nov 4, 2013
2,867
Depends on the duty cycle and duration of run times. If the motors only run for <10 - 20% duty cycle and less than a few minutes at a time the 3 AH batteries are plenty adequate.
You don't need 800+ AH battery to start a vehicles engine just because the starter draws 500+ amps when it operates.
