240Vac to 24Vac and 24 Vac to 24Vdc bridge
MaxHeadRoom
Joined Jul 18, 2013
30,890
Sounds like a linear actuator, the current is fairly small, so should be OK on the relays.
Some have built in limits, but if so, could just be for extreme extents.
Max.
Tryin2learn
Joined Nov 11, 2016
102
Max.
Thanks max .can you help me with the connection 's on the relay that is what I am struggling with .
I understand pin 8 positive 240 vac power in .pin 7 negative in. What I am struggling with 5-6 are the wipers so I put the 24 vdc from PSU onto them pins but what is positive and what is negative o relay .
Then pins 1-4 go to the actuator but such order ?? Thanks max keith
mcgyvr
Joined Oct 15, 2009
5,394
See "pole and throw"
https://en.wikipedia.org/wiki/Relay
A potential problem could be one set of contacts not working properly leading to a direct short.. Relays DO fail even just a single set of contacts may not switch when the other does..
Luckily Omron is a very reliable brand.. But there are also thousands of Omron knockoffs too..
Good thing they invented fuses..
I'll whip up a general schematic for you if I get a chance in a bit here..
Tryin2learn
Joined Nov 11, 2016
102
Hiya no there is nothing wrong with it I hope just need to find out what the wipers are for and which is positive and which is negative thanks Keith
mcgyvr
Joined Oct 15, 2009
5,394
Here is a quicky.. I haven't looked at the datasheet for your relay to even know if you have the right one..
But here is a typical DPDT relay setup for changing polarity of an actuator based on the relay being energized or not..
When the relay is not energized (switch is open) the 24V from the DC power supply goes through contact C on the right side and comes out the NC contact and goes to pin 1 on the actuator..
And ground from the 24VDC power supply goes through contact C on the left side and comes out the NC and goes to pin 2 on the actuator.. This causes it to move to one direction till it hits the limit switch..
Then when the relay is energized (because the switch is closed) 24VDC goes through C and comes out NO on the right side and goes to pin 2 on the actuator and GND goes from c and out NO on the left side and goes to pin 1 on the actuator..
Causing it to move in the other direction till it hits the limit switch..
Hope that helped..
mcgyvr
Joined Oct 15, 2009
5,394
^^ in addition to that it sounds like you have the wrong relay.. But you have yet to post the correct/complete part number of it..
Seems you need one with a 240VAC rated coil and one capable of 24VDC @ 3A on the contacts..
Tryin2learn
Joined Nov 11, 2016
102
Thanks mcgyvr did you get the part no ??. When you get a minute will you double check for me that this one is typical and let me know OK thanks again for your time I was struggling there .
Tryin2learn
Joined Nov 11, 2016
102
Just looked on eBay where I bought it and there are several from different suppliers and they all say 240 vac 24vdc ??.Keith been looking at a data sheet don't fully understand it but to me the 240 power in connects to pin7 negative pin 8 positive 24 vdc goes to pins 5-6 can you check this for me when you have time because I am getting mixed info thanks max Keith
MaxHeadRoom
Joined Jul 18, 2013
30,890
I found the LY2J and found examples out there from 240vac to 12vdc coil, ind LED or non.
The voltage rating of the coil should follow the LY2J-24dc e.g.
Max.
Tryin2learn
Joined Nov 11, 2016
102
Hi'ya just looking at the relay itself on the top it definitely says ONROM LYN-J it has a red led
in the top . On the side it says. 10 A 110 vac
1/2 120 vac
10A 240 vac
On the inside there is a coil similar to a transformer with 220/240 vac written on it .
Any wiser ?? Thanks Keith
mcgyvr
Joined Oct 15, 2009
5,394
ONROM... The "real" company is "OMRON"..
You have fake Chinese junk.. :p
But the relay "should" work as expected in my diagram above..
Energize the coil it with 240Vac from your fan switch and switch the 24VDC power supply with the contacts side of the relay..
The polarity on the coil shouldn't matter..
As soon as you apply 240Vac to the coil pins you should hear it "click".. That click is the "contacts" switching states.. That lets you know its actually working..
Tryin2learn
Joined Nov 11, 2016
102
