24 VDC - 1.6 A to 3.3 VDC - 20 mA Using Resistors
Status
Not open for further replies.
35,309
What are the possibilities?
  1. LED blown
  2. Resistors are not the values you think
  3. At least one resistor is open circuit or high resistance
  4. Battery or power supply is dead
  5. Broken cable or connection
All of these you can check with a simple multimeter.
tony.1307
Joined Jun 20, 2017
7
Can you make sure the led is ok, this is just a very simply circuit, you can check all the wiring and measure the voltage of battery and three resistors and led.
I'm using a multimeter to measure the voltage of the components, but I don't know if I'm doing it right. If I one arm (VΩmA) of the multimeter on the LED's anode and the other (COM) the LED's cathode, it tells me that there's 24 V "passing through the LED" even though I have my 1.2 kΩ resistance right before the LED.
35,309
Voltage does not "pass through".
Currents "pass through".
Voltage is across two points.
I think your LED is toast. Do you have spares?
tony.1307
Joined Jun 20, 2017
7
  1. LED blown
1. That may be the issue since the LED are from a old printed circuit. That said, is it possible I fried them by unsoldering them ? If not, how do I test a LED using my multimeter ? I got that little diode symbol on it, but the value stays at 1.
2. Resistors are all 400 Ω resistance, so : 3 * 400 Ω = 1.2 kΩ, right ?
3. I dont really understand what this means.
4. Tested the power supply with a multimeter and all seems fine.
5. Cables and connections seems fine.
ian field
Joined Oct 27, 2012
6,536
Hi everybody,
I don't have enough knowledge in eletronics to calculate the resistance I need in my resistors to power a LED (3.3 VDC - 20 mA) on a 24 VDC - 1.6 A circuit.
I just need someone to explain to me how I calculate the resistance I need in my resistors.
Feel free to ask for more details !
20mA isn't a big deal for a dropper resistors, but you probably still need some sort of shunt regulator if you need any kind of voltage accuracy.
You might just as well use one of the many 3.3V 3-terminal regulators. At 20mA - your biggest concern is the dissipation caused by your supply voltage. A TO92 size regulator might be enough.
35,309
What is the make and model of your test meter?
Does it have a diode test function or resistance measurement function?
Use either function to test the LED. Try the test with the leads connect to the LED in both directions. The LED should light in one direction and not the other.
tony.1307
Joined Jun 20, 2017
7
Ok everybody, seems like there was only ONE LED still alive. I tested like 5 or 6 of the 10 LEDs I have and assumed that they were all fried. but I was wrong. Everything is working fine now, thanks for the help !
Is there a way to close the thread ?
ScottWang
Joined Aug 23, 2012
7,509
The thread was closed as you wish, if you have any further question then please click the report button, it was on the middle position of bottom line.
Status
