24 hour digital clock logic circuit
arian78
Joined Nov 22, 2021
37
Professor accepted the design! Thanks again to everyone who helped! Now they said I should add a reset button and a button to add to the tens of minutes.
For the reset button, should i just connect the reset pins that i grounded to a switch?
And for the adder button... how can i do that?
dl324
Joined Mar 30, 2015
18,480
Did you explain to the other members of your group how the circuit works and why you did things a certain way? They may need to know that for future work. Did they contribute anything? If you did all of the work, they're not pulling their own weight.
Post schematics for what you've tried.
arian78
Joined Nov 22, 2021
37
hi arian,
Do you have the latest circuit diagram to post, makes it easier to suggest modifications. ?
E
Hello! Yes I'll attach it to this post!
Yes I did explain to them exactly and translated the datasheet of the ics for them so they can even understand better!
Right now this clock is working exactly as it should!
Here's a picture of it and here's the file for it, i'm using proteus 8.9, hope it works for you guys.
ericgibbs
Joined Jan 29, 2010
21,603
hi arain,
Consider increasing the 555 clock rate by, say, a factor of 10 or more, when you press a button.
This will make the 'mins' roll over at a faster rate, so that way you can set the Mins.
E
arian78
Joined Nov 22, 2021
37
hi arain,
E
I can do that by adding another resistor and a switch or dip switch before the tens of minutes and connect it to the pin 3 of 555 right? Or am I taking it wrong?
ericgibbs
Joined Jan 29, 2010
21,603
hi a,
I would just increase the 555 clock into the Seconds Units, when the button is pressed.
The Seconds will go very fast, and so will the Minutes.
E
arian78
Joined Nov 22, 2021
37
hi a,
E
That sounds good too. But a question, just to not bother myself with changing resistors all the time on bread board, can i do such a thing with a bread board? Like connecting these resistors to dip switch, and then connect the rest? If you know what i'm talking about, I'm not good at explaining at all
arian78
Joined Nov 22, 2021
37
Made it work this way! Not very clean... and instead of that switch i'll use a wire in bread board, but it does the job!
Not the last part is just a way to reset the whole thing when necessary... can i do anything with dip switch?
