24 and 12 Counter Problem
pbwc
Joined May 14, 2024
Hello,im student and i must finish project.I should make clock with IC's and i created signal,second and minute but my problem i cant make 24 or 12 counter for hour.When i show on display i see 0,1,2...24 after AGAIN 2 why cant i see 0.I watched all counter videos in yt.In 12 counter i see 0 1,2..12 after that 2.I changed all components and no change
djsfantasi
Joined Apr 11, 2010
9,237
We need a schematic to see how you’ve wired your counter.
Papabravo
Joined Feb 24, 2006
22,116
With two, decade counter chips, you can display 00-23 and decode the output, 23, so you can reset it to 00 when the minutes are 59. So what is the problem?
WBahn
Joined Mar 31, 2012
33,109
That depends on whether he is doing a synchronous or an asynchronous rest -- which underscores why we need more information, preferably a schematic.
dl324
Joined Mar 30, 2015
18,453
Welcome to AAC!
Are you allowed to use any IC's you want? Are you supposed to make a 12 and 24 hour clock.
FWIW, hours in a 24 hour clock don't display numbers 00 .. 23, not 24.
Are you breadboarding the circuit? Or just simulating. As others have already mentioned, we need a schematic and a description of what isn't working correctly.
Papabravo
Joined Feb 24, 2006
22,116
FWIW, hours in a 24 hour clock [don't] display numbers 00 .. 23, not 24.
Typing and thinking at the same time can be a challenge. It happens to me all the time.
