The code I shared is intended to control a two-story elevator using a microcontroller. It utilizes the microcontroller's Timer0 to perform the counting of rising edges.
The function mettreAJourEtat() is defined to update the elevator's state based on the current conditions. It uses switch statements to perform specific actions depending on the current state and inputs.
The main() function is the program's main function. It initializes the necessary variables and ports, then enters an infinite loop where it updates the elevator's state by calling the mettreAJourEtat() function. It also handles the logic for Timer0 counting.
The Timer0_ISR() function is an interrupt function for Timer0. It is called when the Timer0 interrupt flag is triggered. In this function, the frontCount counter is incremented on each rising edge detected, and then the interrupt flag is cleared.
This code utilizes the inputs from RG0 and RG1 ports to detect the states of the elevator buttons or sensors. Based on the current state and inputs, the outputs of RF0 to RF3 ports are controlled to activate relays or other elevator devices.
am experiencing an issue with the Timer0 counter not incrementing. I suspect there might be a problem with either my interrupt or configuration. Can you help me identify the issue?
I have bundled the main.c file, the .hex file, and the Proteus simulation into a RAR archive.
Mod edit: Present attached C code using code tags - JohnInTX
- Update State Function:
- Main Function:
- Timer0 Interrupt Function:
C:
* File: newmain.c
* Author: nader Noomen
* Project For my Master degree
* Created on 25 avril 2023, 17:54
// CONFIG1H
#pragma config OSC = XT // Oscillator Selection bits (RC oscillator w/ OSC2 configured as RA6)
#pragma config OSCS = OFF // Oscillator System Clock Switch Enable bit (Oscillator system clock switch option is disabled (main oscillator is source))
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = OFF // Brown-out Reset Enable bit (Brown-out Reset enabled)
#pragma config BORV = 25 // Brown-out Reset Voltage bits (VBOR set to 2.5V)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT enabled)
#pragma config WDTPS = 128 // Watchdog Timer Postscale Select bits (1:128)
// CONFIG3L
#pragma config MODE = MC // Processor Mode Select bits (Microcontroller mode)
#pragma config WAIT = OFF // External Bus Data Wait Enable bit (Wait selections unavailable for table reads and table writes)
// CONFIG3H
#pragma config CCP2MUX = ON // CCP2 Mux bit (CCP2 input/output is multiplexed with RC1)
// CONFIG4L
#pragma config STVR = OFF // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF // Low-Voltage ICSP Enable bit (Low-voltage ICSP enabled)
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000200-003FFFh) not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (00C000-00FFFFh) not code-protected)
#pragma config CP4 = OFF // Code Protection bit (Block 4 (010000-013FFFh) not code-protected)
#pragma config CP5 = OFF // Code Protection bit (Block 5 (014000-017FFFh) not code-protected)
#pragma config CP6 = OFF // Code Protection bit (Block 6 (018000-01BFFFh) not code-protected)
#pragma config CP7 = OFF // Code Protection bit (Block 7 (01C000-01FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot Block (000000-0001FFh) not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000200-003FFFh) not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (00C000-00FFFFh) not write-protected)
#pragma config WRT4 = OFF // Write Protection bit (Block 4 (010000-013FFFh) not write-protected)
#pragma config WRT5 = OFF // Write Protection bit (Block 5 (014000-017FFFh) not write-protected)
#pragma config WRT6 = OFF // Write Protection bit (Block 6 (018000-01BFFFh) not write-protected)
#pragma config WRT7 = OFF // Write Protection bit (Block 7 (01C000-01FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0001FFh) not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000200-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR4 = OFF // Table Read Protection bit (Block 4 (010000-013FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR5 = OFF // Table Read Protection bit (Block 5 (014000-017FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR6 = OFF // Table Read Protection bit (Block 6 (018000-01BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR7 = OFF // Table Read Protection bit (Block 7 (01C000-01FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0001FFh) not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// Flash Program Memory Code Protection bit (All program memory code-protected)
#include <xc.h>
#define TRUE 0x01
#define FALSE 0x00
void Config_Param_Timer() // Configure le module Timer pour fonctionner en mode compteur
INTCONbits.TMR0IF = 0; // Efface le drapeau de dépassement du Timer0
INTCONbits.TMR0IE = 1;
T0CONbits.T08BIT = 1;
T0CONbits.T0CS = 1;
T0CONbits.PSA = 0;
T0CONbits.T0SE =1;
INTCON2bits.TMR0IP = 1;
T0CONbits.T0PS2 = 1;
T0CONbits.T0PS1 = 1;
T0CONbits.T0PS0 = 1;
T0CONbits.TMR0ON = 1;
INTCONbits.GIE = 1; // Active les interruptions globales
int position_actuel;
int frontCount;
unsigned int etatActuel;
typedef enum {
Etage_0_vers_Etage_0,
Etage_0_vers_Etage_1,
Etage_1_vers_Etage_0,
Etage_1_vers_Etage_1,
} EtatAscenseur;
EtatAscenseur mettreAJourEtat(EtatAscenseur etatCourant) {
switch (etatCourant) {
case Etage_0_vers_Etage_0:
if (PORTGbits.RG0 == 1 && frontCount <= 0 && position_actuel == 0) {
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 1;
PORTFbits.RF3 = 1;
position_actuel = 0;
frontCount = 0;
break;
case Etage_0_vers_Etage_1:
if (PORTGbits.RG1 == 1 && frontCount <= 1 && position_actuel == 0) {
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 0;
PORTFbits.RF2 = 0;
PORTFbits.RF3 = 0;
if (frontCount == 2) {
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 0;
PORTFbits.RF3 = 0;
if (frontCount == 3) {
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 1;
PORTFbits.RF3 = 0;
if (frontCount == 4) {
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 1;
PORTFbits.RF3 = 1;
position_actuel = 1;
frontCount = 0;
break;
case Etage_1_vers_Etage_0:
if (PORTGbits.RG1 == 1 && frontCount <= 1 && position_actuel == 1) {
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 0;
PORTFbits.RF2 = 0;
PORTFbits.RF3 = 0;
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 0;
PORTFbits.RF3 = 0;
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 1;
PORTFbits.RF3 = 0;
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 1;
PORTFbits.RF3 = 1;
frontCount = 0;
break;
case Etage_1_vers_Etage_1:
PORTFbits.RF0 = 1;
PORTFbits.RF1 = 1;
PORTFbits.RF2 = 1;
PORTFbits.RF3 = 1;
break;
return etatCourant; // Retourne l'état courant si aucune transition ne se produit
void main(void) {
EtatAscenseur etatCourant;
Config_Param_Timer();
TRISF = 0;
PORTFbits.RF0 = 0;
PORTFbits.RF1 = 0;
PORTFbits.RF2 = 0;
PORTFbits.RF3 = 0;
TRISG = 0b00000011; // Configure RG0 et RG1 en tant qu'entrées
PORTGbits.RG0 = 0;
PORTGbits.RG1 = 0;
frontCount= TMR0;
TMR0 = 0;
while (1) {
etatActuel = mettreAJourEtat(etatCourant);
// Ajoutez ici la logique pour effectuer le comptage du timer
// Déclaration de la fonction d'interruption pour le Timer0
void __interrupt() Timer0_ISR(void)
if (INTCONbits.TMR0IF) // Vérifie le drapeau d'interruption du Timer0
frontCount++; // Incrémente le compteur à chaque front montant
INTCONbits.TMR0IF = 0; // Efface le drapeau d'interruption du Timer0
