20v dc convert to a ajustable 4 to 20 ma signal
KMoffett
Joined Dec 19, 2007
2,918
Collin,
How do you want to vary the 4-20mA level? Are you trying to create a 4-20mA output transducer? Or, is this to be a test signal to check a 4-20mA receiving device?
Ken
Wendy
Joined Mar 24, 2008
23,859
Do you want to convert 0-20VCD to 4-20ma? I just came up with the reverse circuit, a 4-20ma to 0-5VDC for another thread.
collin shrewsb
Joined Nov 10, 2008
4
Hi bill. the project is to test controllers on the air compressors as a simulator. the origenal layout is a 20v dc + (one wire) running to an air
pressure transducer. this converts to a 0 to 20 mA signal. (one wire return) the idea is to simulate the air transducers. i want to use the 20v + from the controller and vary the 4 to 20 mA signal ( if possible). the controller converts the 4 to 20 mA signal to airpressure reading.as a result i can test the controllers alarm and cut out settings.
