ronsimpson
- Joined Oct 7, 2019
- 4,856
Did you miss that the load varies by ±20%?
The load is "0.5 ohms +/- 20%", but I don't know if simple resistance or a coil.
No I did not miss that.1) If the coil was 0.5 ohms (about) and resistive I could just jam 10V across it to get 20A. or 0.6 ohms needs 12V. or 0.4 needs less volts. There would have to be a calibration to know what voltage is needed.
I did not bring this up because WBahn did and because that is what I do at work. I make and sale high current high Q inductors. I have a 1mH coil made with Litz wire. It is air core because (what I need) but for this probably could be a ferrite core. I stroke it with a GAN-MOSFET.that's just a 1 mH inductor.
Because we can't talk directly to the faculty member we don't know what is in his thoughts. From some experience he does not know that is needed. Only after it fails will we find out that _______. Why didn't you know that?
As to speed, 10uS is not fast in my world. There is no specification for speed, other than 10uS. My guess is they don't understand that two feet of wire is a real problem if the edges are faster than 100nS. Don't worry about speed until they understand what that costs.
We will never learn about what this is or why.
