What are the values of R11 and R12?Hi.
Have this setup where i will need up to 1,5A 5vDC.
I need to control this with a PWM from MCU,
But how can i connect just one transistor ? as i can see the transistor need at least 5v on base to operate. therefor i have connected 2 in series.
But will that work, or is there a better way ?
If i use the P-Channel, witch one should i use, and what resistor size. ?
ok, lets try to explain a little better. I have a MCU, need to control this : The TLC9225 is controlling all my LEDS, have many.Thanx, some say it will not work, and there's nothing i datasheet abouth it, but it will proberly work, save me a lotYou don't need the driver transistors.
Use the TLC5925 /OE pin for PWM control.
You will have to invert the PWM duty cycle in software. LOW signal to /OE turns on the LED.Thanx, some say it will not work, and there's nothing i datasheet abouth it, but it will proberly work, save me a lot
Did you miss this in the datasheet?Can be up to 50-60 in parellel(not same resistor). and 10-20mA, so total MAX 1200mA and 6W.
You cannot have more than two LEDs at 20mA on any output. Also, connecting parallel LEDs a constant current driver does not divide the current evenly among the LEDs.• Constant Output Current Range: 3mA to 45mA
| Thread starter | Similar threads | Forum | Replies | Date |
1 Series Oscilloscope | Test & Measurement | 2 | |
| M | Fluke 73 series 1 Multimeter repair | Technical Repair | 10 | |
| 7 | 7400 series's | Digital Design | 18 | |
Audio amp pwr transistors (low hFE, and other spec rot) | General Electronics Chat | 16 | |
Thyristors Did to Power What Transistors Did to Logic | Power Electronics | 3 |
