2 stage opamp biasing current
AMSA
Joined Jun 30, 2015
10
Hi everyone,
I would like to know if someone knows why the current in the second stage of a two-stage opamp, has to be bigger than the first stage?
What happens if the current in the second stage is bigger than the first?
Best regards.
shteii01
Joined Feb 19, 2010
4,644
If it is power amplifier, then first stage amplifies voltage, second stage amplifies current, the total effect is power amplifier because Power=V*I.
anhnha
Joined Apr 19, 2012
904
Hi, the amplifier is a 2 stage OpAmp with Miller compensation.
Regards
There are two poles and one zero. To make it stable and get the desired phase margin, you should seperate the second pole and zero far from the origin for a specific phase margin.
AMSA
Joined Jun 30, 2015
10
Sorry for causing all of this misunderstanding.
I could put a picture but it is a simple 2 stage opamp, miller compensation, using MOSFETs and say pmos input pair.
Just one comment about anhnha response.
I have thought about that, because the gm in the second stage define the second pole, so bigger current bigger gm bigger bw.
Now let analyse it from slew rate perspective. Same question but now supposing that the opamp is slewing. What are the differences?
ebeowulf17
Joined Aug 12, 2014
3,307
Please include schematic. Even if some of the experts here can answer your question based on your sparse description, less experienced people, like me, who are still learning will benefit greatly from seeing the schematic while reading the discussion. Thanks!
shteii01
Joined Feb 19, 2010
4,644
I believe it is secret and covered by NDA.
ebeowulf17
Joined Aug 12, 2014
3,307
I thought that one if the goals of open, public forums like this was for everyone to be able to learn from the discussions, not just for a few individuals to get private consultations.
If the question is so specific to a unique, proprietary circuit that the schematic can't be shared, it seems like it couldn't be answered without that schematic.
On the other hand, if the question refers to common, well-known arrangements, then generic representations of that circuit should suffice.
Is the circuit in question something like these?
Bordodynov
Joined May 20, 2015
3,435
1. An output stage using a current generator can not give more current than the current generator.
2. There is a property of FETs: greater voltage gain at lower currents (for high-resistance loads such as a current generator). This can easily be shown for the simplest model of a transistor:
Id = B * (Vgs-Vto) ^ 2 ==> S = (d Id / d Vgs) = (Id) '= 2 * B * (Vgs-Vto) = 2 * sqrt (B * Id)
Rout = 1 / (Lambda * Id)
Gain_max = S * Rout = 2 * sqrt (B * Id) / (Lambda * Id) = 2 * sqrt (B) / (Lambda * sqrt (Id))
In fact, it is necessary to reduce the current density of the transistors of the first stage of the amplifier. And this is done in two ways: reducing the current or increasing the size of the input transistors. The second method is used to reduce noise.
I will make a note on the use of formulas.
They cease to be true in the subthreshold mode of transistors. Those. To obtain a high gain, it is necessary to use a subthreshold mode.
