2 Mcu's to one ethernet port
ton88
Joined Nov 10, 2019
18
Hello iam trying to connect 2 MSP432E mcu's to one ethernet port, iam thinking a 3 port ethernet switch would work or a optical isolator would work.I was curious if other ways exists such as just being able to connect both Mcu's ethernet traces to each other.any iput is appreciated thanks
Papabravo
Joined Feb 24, 2006
22,111
You connect the 2 MCUs as separate nodes, and all the network stuff works as intended. You cannot effectively multiplex 2 MCUs on to one port. To even suggest such a thing betrays a fundamental misunderstanding of the MAC and Physical layers of the network, It would be highly impractical.
