I think the reasonability test favors 320mA TOTAL. The LEDs run on 2.1-3V. And 32mA apiece is also reasonable assumption. 320mA per LED just doesn’t sound right for 3V.The diode needs to support the power going to your other lights... If you're running 10 LED's at 320 mA each that's 3.2A. Or if it's 10 LED's at 320mA total it's only 0.32 Amps...
It’s ok. We’re both right!You might be right but I've been playing with LED's a lot lately:
https://www.ledsupply.com/blog/1-watt-3-watt-high-wattage-leds-explained/
