1HZ Clock From A 10Mhz Oscillator Module
Bordodynov
Joined May 20, 2015
3,431
Thanks Bordodynov.
It would be really helpful if I had someone's actual .asc file. A picture does not help. I suspect that
the problem I am having is with the path and/or the parameters in the CD4060B Component
Attribute Editor.
M
You have entered incorrect parameters for low-frequency quartz. Three orders of magnitude less and an order of magnitude more.
If you use my library, then do not place file access on the diagram. I tried to calculate the circuit in LTspice, but the calculation is slow. So I created a hierarchical model of the CD4060 in Qpice and did the calculations. This took a minute and a half of computer time.
maker_2023
Joined Nov 20, 2023
199
I used your model and used the parameters specified in your .asc file. If my parameters are incorrect
then why not share?
maker_2023
Joined Nov 20, 2023
199
It works very well:
I have a circuit that Bordodynov sent me in post #45. I made no changes to it and it does not work. Yours
does show an output but his just shows a straight line at 0 volts. Are you using Model QZS32768?
There must be something different somehow. Would you mind posting the .asc and I can run it at my end.
Thanks,
M
Danko
Joined Nov 22, 2017
2,238
does show an output but his just shows a straight line at 0 volts. There must be something different some
how. Would you mind posting the .asc and I try run that at my end.
Thanks,
M
I used same @Bordodynov's file from post #45, without changes.
After simulation is running, see on status bar.
When "Simulation Time" will 2 sec
and "Transient Analysis" will 100% done,
then your simulation is fully finished.
maker_2023
Joined Nov 20, 2023
199
Hi Danko:
I am just curious, how long should the simulation take? Perhaps I don't wait long enough.
It has been runing for 10 or 15 minutes and the status bar is not changing. I have also
attached my settings in the Component Attributes Editor.
M.
Danko
Joined Nov 22, 2017
2,238
Bordodynov's circuit still does not work. The sim goes so far and then freezes.
Obviously, there is something different between our circuits and I guess it
is a big secret.
Why would I want this?
M.
I think it may be difference between computers.
@Bordodynov's file on Intel(R) Core(TM) i9-10900, 10-core CPU @ 4.49 GHz, 16 GB,
Windows 11, LTspice XVII,
time of simulation = about 3 hours, on speed 200 μs/s, without problems.
Your image in post #53 indicates that your sim didn't run to completion and it
might have froze at Simulation Time = 26.7749 ms or 30.6894 ms like mine did.
My simulation was not frozen, I took image from running program.
Bordodynov
Joined May 20, 2015
3,431
I used the Qspice program and the simulation time on my home laptop was:
Total elapsed time: 419.938 seconds
On my work computer the simulation time is 90 seconds.
I have posted below the general electronic circuit and the contents of the hierarchical circuit.
