18v 5ah Litthium battery to 12v
Warpa
Joined Jul 30, 2017
6
Hi, I've just been reading a similar project but due to differences in batteries and power want to make sure I get the right regulator.
I need quite a bit of advice here regarding runtime and regulators. I'm looking to buy a 100w rms, or 200w rms class D monoblock car amplifier that will be powered by an 18v 5ah Dewalt lithium battery. I'd like the battery to last 8 hours on a single charge and will be powering a 6 inch mini sub. The mini sub will be a bass back up for the Dewalt toughsystem radio which I believe has Clarion car components in it. Any advice much appreciated.
Papabravo
Joined Feb 24, 2006
22,116
If you know nothing about regulators, you should start with the simple case of a linear regulator: an LM317 for example. They are simple to design and use but they have one MAJOR drawback. The more current you pull through them, the HOTTER they get. For example if the 12V load pulls 1 Ampere, the regulator must dissipate (18V -12V)*1Ampere = 6 watts. A TO-220 package with a really good heatsink can manage 10°C/watt of temperature rise from junction to ambient. In your case that will be 60°C. Assuming the ambient temperature is 20°C, that means the junction inside the regulator will be at 80°C. This is not impossible but you do have to design the heatsink and the mounting with some degree of care.
If this doesn't work for you, then we need to consider a switch mode DC-DC converter. Before you consider building one of these you should think about buying one. This doesn't even include conversion losses.
I'm curious about how you intend to get 100-200 watts out of the 5 Ah battery. If you do it might last an hour: 18V times 5A = 90 watts and 18V times 1A = 18 watts.
Warpa
Joined Jul 30, 2017
6
That's a good idea and a much better alternative. I'll see what I can find and hopefully the will be a 200w rms subwoofer amp out there.
38,948
Can you buy a Class D bass amp that will operate directly from the battery voltage?
Most of them are rated to run from 14.4V so some may run at 18V without a problem.
38,948
The average bass music energy is much less than the peak required for the large bass thumps, which is why you want a large wattage amp.
So the average draw from the battery will likely be no more than a few watts.
Papabravo
Joined Feb 24, 2006
22,116
I guess that means he might get 8 hours out of a charge depending on his musical tastes. Compare:
  1. Toccata and Fugue in D Minor
  2. Also Sprach Zarathustra
  3. Dark Side of the Moon
tom_s
Joined Jun 27, 2014
288
generic 24 -> 12v 10a inverter will probably work, they generally switch mode buck inverters.
i use them when installing 12v 2 way radio's into vehicles running 2 batteries (24v)
