I don't know if we have a current tracer.Here are some possible approaches:
1) Get a current tracer
2) Get an IR imaging camera
3) Get a can of freeze mist
4) Start cutting away at the 15V power rails on the PCB.
I will check that out! thanks!Hello,
Check C5 and C6.
Bertus
What do you mean by board level?Could this problem be at the board level and not because of a component damaged?
If you apply +15VDC and it is shorted to GND, all the high current is going somewhere back to the power supply.I don't know if we have a current tracer.I have never used one
I don't know if we have an IR imaging camera.
I can find a can of freeze mist. What do I do with it? What should I see or look for?
what is start cutting away at the 15V power rails on the PCB?
Thanks for your help!
I lifted a lead from each CAP and do a resistance test and its not shorted.Hello,
Check C5 and C6.
Bertus
I like that idea. But I only have a can of freeze mist. So how do I use it?If you apply +15VDC and it is shorted to GND, all the high current is going somewhere back to the power supply.
The idea is to trace where the current goes and usually the shorted component is going to have elevated temperature. You are trying to find which component on the circuit board is getting the hottest.
If you cannot locate the fault visually, you have to do a binary search.
You divide the circuitry in half and cut the power supply trace leading to one-half of the circuitry.
To me, board level and component damage is referring to the same thing.
I will youtube this and purchase one for troubleshooting purposes. thanks!I must be one of the few people on the planet that owns an HP546A Pulser and HP547A Current Tracer. (They come as a kit with other parts.)
If you can find a pair for sale, it is worth their weight in gold for this type of trouble shooting.
