15kHz Sound Generator
Colin55
Joined Aug 27, 2015
519
This whole thing is normally done with a flyback or feedback oscillator with inductor and piezo diaphragm and a single transistor.
What "whole thing"?
The requirement for 15kHz and 90dB.
AnalogKid
Joined Aug 1, 2013
12,281
What "whole thing"?
Now that I see what you are talking about - the hard part is finding a 3-lead piezo element that resonates at 15 kHz.
ak
Colin55
Joined Aug 27, 2015
519
standard audio amp for the power. I see no reason to build anything if you string together a function generator, an amp and a tweeter.
Why don't you add a CRAY computer to your string of absurdities.
wayneh
Joined Sep 9, 2010
18,171
The TS says he wants 15kHz at >90dB. I could do that in about 20 seconds by walking upstairs and connecting my iPhone to my home theater, and setting a free function generator app to give me a sine wave at 15kHz.
Do tell why you want to make it more complicated.
wayneh
Joined Sep 9, 2010
18,171
You are assuming the original poster has a staircase he can walk up.
I'm assuming that someone able to get on the internet and join an electronics forum probably has both a smartphone and an audio amp. If not, fine. He's probably got several constraints we haven't heard yet, because that's typical of threads here. We don't learn the real goals until 20 posts in. You've anticipated that he wants a standalone, compact solution and you may be right.
bertus
Joined Apr 5, 2008
23,010
@Colin55 , How can you say that a LM386 can give the 80 Volts?
It has a maximum supply voltage of 15 or 22 Volts depending on the model.
Just have a look at the datasheet.
Bertus
35,215
To debunk any short comings of the 555-timer as alluded to by detractors, I tested an NE555 timer chip at 5V supply.
For the rated 200mA output, you should be able to drive a 25Ω load.
Running in astable mode at 1MHz, 50% duty cycle with a 15Ω load on output pin-3, the output voltage measured on an oscilloscope was 3.5V.
With 15Ω load, that is 233mA output drive.
There was no appreciable increase in chip temperature using a finger test.
AnalogKid
Joined Aug 1, 2013
12,281
How square was the output?
ak
Colin55
Joined Aug 27, 2015
519
What use is an output voltage of 3.5v ? You could only use it to power the motor on an electric bike at 20mph.
Test the chip at 12v and 15kHz and feel the heat. At 120mA you can just keep your finger on it and 200mA "blows you away."
