14 A at 1.6 V for a large IR 850 nm LED?
Ya’akov
Joined Jan 27, 2019
10,355
That COB has 50 LEDs, and it's actually rated at 7A continuous. That would run each chip at 140mA. This is not completely crazy, but it is much higher than a long life would warrant.
The forward voltage simply must be wrong. If every one of those chips were in parallel, the lowest it could be is the forward voltage of a single one, and I don't think 850nm LEDs have such a low forward voltage.
As far as supplying the voltage, which part of it are you confused about?
oz93666
Joined Sep 7, 2010
742
I've come across many crazy listings before , text that bears no relation to the product (particularly Aliexpress) but your one takes the biscuit .... I think the person making it was out of their head .
Here's what I believe to be the same item from ebay ...
50W 850nm Infrared IR High Power LED Bead chip for Light Bulb Lamp 15-20v 1750mA
The picture is identical to your link ,,, 50W , so it has 5 lines of leds ,,, each line has 10 leds in series.
