12v USB Hub Where should I connect ground
john2k
Joined Nov 14, 2019
219
I have a 12v USB hub and it has 3 pin to connect power to it as pictured below. The + and the ground seems to have two pins. Which would I connect the ground to? both? why would it have two ground pins?
Picture below:
ericgibbs
Joined Jan 29, 2010
21,513
hi john,
As you may have seen the +24v and GND have a White bar to identity the pins, its not unusual for manufacturers to use what type of connectors they have lots of in stock.
E
dl324
Joined Mar 30, 2015
18,442
One or the other, but not both.
It looks like the two connections on the right are both ground, but it isn't clear due to the angle of your picture. If you have any doubt, use a continuity checker.
MaxHeadRoom
Joined Jul 18, 2013
30,758
I agree with Eric that the centre and RH terminal appear to be common, if so, one may be for connecting to earth ground, in a PC, the common would be bonded to earth anyway.
Especially if this is a stand alone unit.
Max.
john2k
Joined Nov 14, 2019
219
That's what I thought but then when I removed the connector which is removable then the pin labels look like below so it's a little confusing
dl324
Joined Mar 30, 2015
18,442
so just using the outer one and leaving the middle one off completely is fine?
Yes. If it came with a supply, was it using both grounds? That wouldn't make much sense because the ground connection carries the same current as the power connection.
john2k
Joined Nov 14, 2019
219
No it doesn't come with power supply. I've wired it with the outer pins and left out middle one and seems to be working fine so far. I did a continuity test between the two ground pins and the multimeter beeps. But then again it seems the continuity beeps between any pins lol.
