12v to 6v when connected but 12v to 12v when not?
Killerbee65
Joined May 15, 2017
256
Thought numbers might help.
Killer still doesn't get it even though I said it in post #3.
I do get it but I am looking for convenience and button cells are what I need thank you very much. I don't know much about batteries i'm just starting engineering classes in middle school right now but i'm getting there, anyways I've seen button batteries that have a lot of current compared to others like the br3032 it supposedly has a current of 500 milliamps. I only need about 1 to .5 amps to charge a mobile device.
The specification on batteries is in mAh, or milliamp-hours. The battery you referenced has 500 mAh capacity. Ideally, if you could draw 500 mA out of the battery, it would last for an hour before being drained.
However, the datasheet that was previously referenced shows this capacity level only for small load currents, around 1 mA and below.
Above that load current, the 500 mAh capacity is reduced and the output voltage is also reduced. Both items shown on the datasheet.
You need to find a battery that maintains that capacity and voltage for the currents you desire in your load.
This means looking at the datasheets and trying to understand the numbers and graph on them.
Try looking at the tiny LiPo batteries suggested above. Look for some datasheet from the manufacturer or distributor of the parts. I found the other information on a distributor website, digikey.com.
Killerbee65
Joined May 15, 2017
256
yea actually i was just looking at those and I was thinking of making a power bank instead of having to replace batteries so I am looking for a schematic of a power bank but can't find a really detailed one. Think you can help?
I can help through the forums as I have tried to do here. If you come up with some ideas, we can try to point you in the correct direction.
Killerbee65
Joined May 15, 2017
256
ok thanks. my new idea is extending my board by adding anything i need for a rechargeable power bank using a lipo battery but I can't find anything that's either a full picture of the schematics or the schematic is completely different than the one I am using.
Look into something like Battery Babysitter from Sparkfun. They provide plenty of documentation on products that may help. You ned to read the documentation on the ICs involved to see exactly what is involved with that type of project.
Killerbee65
Joined May 15, 2017
256
so I got my battery from a xiaomi portable charger and im wondering how can i implement this into my board and make it so that I can recharge it whenever I want?
oh and by the wayScreenshot 2017-05-19 at 9.15.58 AM.png ignore the button cell batteries this is an old concept of my current project
