Ok guys, Here is what I'm doing. I have a 1988 Corvette and I'm fabricating an LED Eagle Eye set-up. The vehicle has a 2-wire set-up with variable voltage at the light switch for running lights and brake/turning signal. What I'm trying to do is fabricate an outer ring inside each light assembly for the running lights (lower voltage) and and when turn signal or brake lights come on all leds will illuminate with full 12v. Problem is the two wire harness.
Is there a electrical part that can discriminate between a lower voltage and higher voltage? Am I lookat this all wrong? Is it just a wiring issue? Any help is greatly appreciated.
