LED tail light circuit board dimmed
BaronTR
Joined Jan 5, 2023
6
Hi everyone,
The LEDs in one of the tail lights of my car went dim and I am trying to fix it.
There is a small board that I am sure is not working properly since I have verified it with the board from other tail light.
As you can see in the picture, left one is the problematic one.
I have checked resistance readings for every single resistor and all look alright. When I supplied 12V to the board and was doing some continuity check on the board, I accidentally touched one of the transistors and all the LEDs started to work properly! The place that I touched with the cable can be seen in the video. After some research I found out that I simply connected Pin number 1 and 2 of a MJD31 (https://www.onsemi.com/pdf/datasheet/mjd31-d.pdf), which were BASE and COLLECTOR.
As my circuit knowledge is very limited, I am pretty lost and I don't want to just connect these pins to make it work. I would really appreciate it if anyone could help with identifying the problem on the board.
Thanks in advance!
dl324
Joined Mar 30, 2015
18,476
Welcome to AAC!
Does this mean that if you swap the boards, the defect moves with the board you've identified as bad?
In properly designed boards, resistors are unlikely to fail (unless they're being used as fuses to protect other circuitry). In-circuit measurements don't always give the expected results.
Post a picture so we don't have to look at a bouncy 45 second video.
BaronTR
Joined Jan 5, 2023
6
Exactly.
Is there a better/more reliable way to check?
Here is the picture of the transistor pins that I connected.
dl324
Joined Mar 30, 2015
18,476
Without having a schematic for the board to see what else is connected to the resistors, one terminal would need to be disconnected.
Are you able to verify that the emitter of the transistor is connected to ground, trace the components connected to the collector to the positive supply, and determine what's connected to the base?
28,399
What I see that looks like either water damage or overheating on the back of one of the boards, while the other board looks undamaged. Certainly water between an energized section of board copper and any grounded material will cause damage. So the problem might possibly be damage to that discolored section on the bottom side of the one board. That can be repaired with wire and solder, but some real soldering skill is required.
BaronTR
Joined Jan 5, 2023
6
I checked the copper trace on the board and found the problematic part!
As @MisterBill2 guessed, the discolored part was the problem. One of the copper lines has a break on it, probably due to the water damage. (This specific tail light actually had a recall from the factory due the bad seal gaskets. So it is very likely that some water leaked inside the tail light.)
After some cleaning I connected the two ends with a cable to test. And Voila!
I am not sure if it is any safe to connect the ends this way though. Would you suggest anything to make it more reliable for the future? Would epoxy help? I will anyways use silicone on the gaskets to stop water leakage.
Here is my solution:
Thanks for the suggestions!
BaronTR
Joined Jan 5, 2023
6
While I was putting everything back, the light flickered. So I am guessing that the connection is not that good.
Do you guys think that connecting BASE and COLLECTOR pins on one of the transistors is safe? (I read that it makes it a diode) Because it is easier for me to solder and it works really well.
dl324
Joined Mar 30, 2015
18,476
Would doing that affect other functionality?
Improve your soldering skills. The wire you used was overkill. You could have laid a #30 AWG solid wire over the trace that had corroded. If you couldn't solder a bare piece across the part that opened, you could use insulated wire between the two points where you tried to solder the big wire.
BaronTR
Joined Jan 5, 2023
6
The board has only one function. It lights the LEDs up for parking lights. The rest of the bulbs (brakes, reverse and turn indicator) are on a different electrical plate and powered up separately. So if it fails it will just fail the parking lights which is already dimmed at the moment.
The problem is that I don't have wires and necessary tools. But I will try to supply.
