12v sensor switch
byronious
Joined Jan 17, 2015
2
its a 12 volt DC sensor switch. There's three holes to insert wires into. one has an L. one has an N and o:..ne says load. I don't know what thismeans. can someone please explain this to me?
ericgibbs
Joined Jan 29, 2010
21,442
hi,
The letters L N and Load usually apply to mains wiring connections.?
When you say 12V DC , is that the control voltage input.
Post a part number or link.
E
byronious
Joined Jan 17, 2015
2
this is an extremely very simple on off switch it came from overseas so there's not a part number that I can find. Its made for 12 volts for light LED lighting and what not.
30,663
Generally a simple contact closure switch that is marked that way is one that has an internal on/off indicator light/led.
If it is a solid state switch then the load terminal could be a NPN or PNP open collector.
