Have tried it in another 12v supply ( Battery Charger ) and it works fine !It sounds like the bulb is defective.
Don't know, was given the lamp ! .Did it ever work in the lamp?
It does say 12v in the heading !, LED Lights will use a lot less amperage than halogen bulbs !If I had to guess, and with the amount of information I have, I have to...
Assuming the lamp is low voltage (12V), the LED is drawing too much current for the supply.
HiHello,
There are 12 volts power supplies for halogen lamps that require a minimum load to work properly.
When the load is to low by the led, the powersupply could go blinking or even stop.
bertus
You can calculate if this is reasonable. What is the wattage of the working halogen bulb?Hi
Thanks for that, yes do remember something like from before, so the question would be what would be the best way to apply another load ( Resistor in series ) if so what value would I be looking at to slightly up the load from ( I think 3w max) for the LED, really want to do the min, could start high and go down with he resistor, but what value would I start with ? .
cheers
Spijke
HiYou can calculate if this is reasonable. What is the wattage of the working halogen bulb?
You will have to put the additional load in parallel, not series, to decrease the resistance and increase the current.
The downside of this is you will be just heating things up and using more power without getting anything else for it.
Thanks for your reply, yes sorry in parallel, yeh true I won't be benefitting from doing that, just an exercise really .
cheers
Spike
That would require 7W to be dissipated by the resistor. That is going to get very hot.Don't have a bulb for it, will tale 12v max 35A Halogen , but hope not go to has high as 35W though, hoping the LED will come on round 10W load including the approx 3W for the LED ! .
cheers
Spike
Yes, could I not use 2 or 3 resistors to obtain the same results ! .That would require 7W to be dissipated by the resistor. That is going to get very hot.
Each resistor would get less hot but the total heat will be the same. You will be making a little desk heater.Yes, could I not use 2 or 3 resistors to obtain the same results ! .
I could just start with a high resistror and see what happens with the LED bulb, bit of a guessing game really, but what would be a high resistor to start off with !Each resistor would get less hot but the total heat will be the same. You will be making a little desk heater.
