12v dc battery circuits
pat789
Joined Aug 26, 2023
14
I was wondering if I need to put a fuse between the battery and each appliance in the circuit? If yes should I use a fuse box. Thanks
wayneh
Joined Sep 9, 2010
18,136
Fuses protect wiring, and the power source, against a short at the load. In general they don't protect the load from destroying itself. So the decision to add a fuse depends on the details of the system.
pat789
Joined Aug 26, 2023
14
It's an automatic chicken door, so it has 12v 10w solar panel, 12v 3Amp linear actuator and a 12v light sensor switch
38,725
Generally a fuse is to protect the wiring based upon the wire gauge or the appliance current, so that a short doesn't cause a fire.
The fuse generally does not otherwise protect an appliance from other damage.
ericgibbs
Joined Jan 29, 2010
21,550
hi pat,
I assume your Solar panel charges a 12v battery which powers the linear actuator etc.?
Do you have a simple sketch of your project you could post?
E
ericgibbs
Joined Jan 29, 2010
21,550
hi pat,
I would always fuse the output of a lead acid or SLA battery.
Use a 5Amp fuse from say the battery positive terminal, as you have shown in your diagram
E
Update: do you have a datasheet for the solar panel?
pat789
Joined Aug 26, 2023
14
So will one 5 amp fuse will protect all the appliances? The solar panel doesn't have a data sheet unfortunately, it's says 12v 10w, is all on the back of it. I'm using Awg 22 wire that can use 7amps. Would that be correct as long as the appliances are less than 7amp?
pat789
Joined Aug 26, 2023
14
Hi
Does that mean as I'm using wire rated for 7 amps I should use a single 5 or 10 amp fuse straight after the positive battery terminal which would prevent a short in the wiring and battery?
ericgibbs
Joined Jan 29, 2010
21,550
hi pat,
When I said basic, I don't see how you are controlling the charge of the battery by the solar panel?
What is the 'power antenna'?
E
