MisterBill2
- Joined Jan 23, 2018
- 28,306
Switching the power to the high voltage generation module using a 12 volt DC relay powered by the same power supply make more sense because relay is far more tolerant of any high voltage spikes that might happen. In addition, a relay is simpler to connect and mount, and does not require any electronic expertise to service in the event of a problem. And one of those automotive-type cube relays should serve very well. And a replacement would be available from many sources for many years to come. THAT is why I am suggesting using a normal electromechanical relay.Here is picture of new gun with cascade inserted.View attachment 200634
