12V battery solar charger
Pai
Joined Aug 28, 2016
2
Hello everyone
Im new to this forum from South Africa, doing a small hydroponic project for developing rural settlements who struggle during the crop season! and would like to know if the following items I want to get will work well together. Its basically a solar powered hydroponic tower. I tried to give as much information as possible and drew a picture on how i would put it all together lol ¯\_(ツ)_/¯ idk (Attached!)
Battery
12v 7AH Rechargeable valve regulated sealed battery
Constant voltage charge
Voltage regulation standby use 13.50-13.80v
Cycle use 14.40-14.70v
Solar charge controller
Rated load current 10A
Rated charge current 10A
Work voltage 12/24v
Water pump
Voltage DC 6v ~ 12v : 18W
Head height 1.5 - 7m
Flow 246 - 800L/H
PC Fan
DC 12v
0.42A
Control power timer switch (it would be every 20min 24/7)
Rated Voltage:12V DC
Full Time Range:1Min-168Hours
Contact Capacity: 16A(8)A,250V AC
Resistance load: 16A
Inductive load: 8A
Internal battery:1.2V/40mA(rechargeable batteries)
Operate Temperature:-10~+40°C
Programmable:17times(week or day)
Minimum interval:1 minute
Solar panel
Normal Power – 20W
Normal Power Voltage – 17.5 V (±0.5V)
Normal Power Current Impp (A) – 1.1 A
Open Circuit Voltage – 21 to 22 V
Short Circuit Current – 1.3 A
L.E.D's x3
( ͡° ͜ʖ ͡°)................................................................................lol
if my drawing offends you im sorry:p
Thanx!!
ScottWang
Joined Aug 23, 2012
7,503
So, you already bought all the stuffs or you want to build them?
What's the meaning of 24/7?
>Programmable : 17times(week or day)
More details.
What's the meaning of Impp? (Amp, Input or what)
According to the block diagram, the device on the right side, they all connected in series, I think their could be have a problem, could you explain all the details according to block diagram, such as when the timer time up what will be happen, and according to what condition to set the timer, what time the water pump, pc fan, led will be active, you didn't describe the spec of leds.
R!f@@
Joined Apr 2, 2009
10,004
Hmmm !
A 12V 7AH battery requires 0.7A Current limited charger so that battery life can be maximized, so I would chose a solar charger of around 1 to 2 Amps to cut down cost. A 10 amp Charger is overkill.
plus the charger needs to be a SLA charger type since they require a constant current to charge at max of ~13.85VDC.
Other than that you are good I believe.
Plus everything needs to be connected in parallel.
The LED details are needed as like, RED, GREEN etc. Since different colors take different voltages. You can connect 3 of them in series ( 12V supply ) but still you will need a series resistor which can be identified once you chose the LED color and type (assuming 5mm standard LED)
PS.. the pump will be connected to Timer (so not all in parallel)
and if you like to charge the battery at low sun light, you might need to find a panel than can supply ~20V at 1A in that level of sunlight. But the panel you describe will work in Good Sunlight
Bernard
Joined Aug 7, 2008
5,784
Average drain about 1 A @ 50 % duty. One day = 24 Ah. Needed battery maybe 2X = 48 Ah.
Solar panel needed, 48 Ah / 8 h. of sun = 6 A, or about 72 W.
Timer, 555 IC & relay.
Review of figures is suggested.
mubarakk
Joined Dec 21, 2010
7
Hello everyone
Battery
Work voltage 12/24v
Water pump
Flow 246 - 800L/H
PC Fan
DC 12v
0.42A
Inductive load: 8A
Solar panel
Normal Power – 20W
L.E.D's x3
Thanx!!
I want to ask, were you able to complete this project. I am working on something similar and would appreciate your hep. thanks.
