12V air compressor consuming a lot of current
Dritech
Joined Sep 21, 2011
907
Hi all,
I have a small air compressor with the following electrical specs:
* Voltage: 12V DC
* Max. Amperage: 16A
This compressor was powered from a bench power supply at 12V 5.5A. At this current setting, the compressor is consuming 5.4A (which I an assuming is the max it can provide) and the voltage is dropping to 10V.
Although the maximum amperage is stated to be 16A, I am finding it strange that it is consuming all this current without any load (just the mechanism of the compressor). Is this normal? If not, what can be causing this high current consumption?
What i did notice is that the brushes may be a bit worn out. If this is the case, could this cause the current consumption to increase?
geekoftheweek
Joined Oct 6, 2013
1,429
As noted they aren't very efficient to start. You are still moving an unlubricated piston without a load. It might have some sort of coating to help, but it's just going to be enough to keep it from burning up after a few uses. The air coming out of the hose is somewhat pressurised also due to the size of the cylinder in relation to the hose diameter.
28,258
Consider that the 5.5 amps is only a third of the full load current, that value is probably reasonable. If the brushes are a bit worn, it already has had a fair amount of use, and so it might even benefit from a bit of lubrication. Is this one of the portable devices with a plastic case surrounding it? Have you opened the case and checked to see how freely the motor turns? A drop or 2 of oil on the bearings may help a bit. Likewise, the compressor may be in need of lubrication. If a hug it has been out of use for a while the cylinder lubrication may have deteriorated. And in some instances the polarity of the supply matters.
The realm of "small 12 volt compressors" covers a huge spread of quality levels, from those with ball bearings and teflon coated pistons at the top end to those with poor sleeve bearings and a wobble-plate for a piston at the bottom end. Those are seldom worth much effort.
In addition, if the 12 volt supply is dropping to ten volts then it is already overloaded, probably not doing the supply any good at all.
So the first advice is to see if some lubrication may improve the operation a bit.
Dritech
Joined Sep 21, 2011
907
Hi all,
Thank you for your replies. I dismentled the compressor, cleaned and lubricated. The current consumption went down to around 5.3A, but at least I am not seeing any voltage drop.
28,258
Now it will be an education to try using the compressor for something like inflating a tire. Or did you have some other application in mind? The small 12 volt compressors that I have seen are not intended for constant running applications.
Reloadron
Joined Jan 15, 2015
7,943
Not surprising, the better ones I have seen consume 10 ~ 15 amps. Just don't use one in an accessory socket rated for 10 Amps max unless you want to replace automotive fuses. Most do have a fuse in their plug rated for their max current plus overhead.
Ron
geekoftheweek
Joined Oct 6, 2013
1,429
I don't recall the specs off the top of my head (can't look it up right now), but fuses can hold more than their rated current for a time before blowing. The magic number is 1.6 times the rated current has to trip within a certain amount of time {one second I think). The wiring may or may not hold up depending on what is used. Obviously manufacturers aren't going to build the circuit to constantly push the limits, but a few minutes running a compressor probably won't hurt most of the time
Considering most automotive tires are around 30 : 40 psi and the compressors are usually good to 100 psi or more the chances of hitting the max current is relatively low.
Tonyr1084
Joined Sep 24, 2015
9,744
If you have an underrated power supply, such as one like yours, capable of 5.5A @ 12V, when you try to draw more current than the 5.5A the voltage WILL drop. If you're reading 10V then that and the 5.5A, you're running just about 15.5 amps rating, which should be expected.
Rather than testing a 16 amp DC motor on a 5.5 amp supply, try running it from a car battery. You'll see the voltage remain stable and the compressor will run at full power. Off hand I don't know how many amps those 12V compressors typically draw, so just going off your 16 amp comment, I'd say the 10V is expected.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Hi all,
What is the nature of the compressor? Often a simple piston type, small DC motor with a reduction GB.
At least that is what my el-cheapo I keep in the trunk is.;)
28,258
Once again, what is the intended use? If it is to pump up car tires then the very safe way is to use battery clips and connect it directly to the battery.
BUT the TS may have a different plan to use it for some other purpose, we have no clue.
AND this is certainly not the venue for poor jokes, as in post #11. Very much off topic, as well.
Tonyr1084
Joined Sep 24, 2015
9,744
Yes, I know. It's being moved to the jokes thread. You can make further commentary on it there. And yes, it certainly was "Off Topic" for this particular thread. It was an unintended mistake.
Tonyr1084
Joined Sep 24, 2015
9,744
this is • • • not the venue for poor jokes
Sorry - didn't mean to offend the "Taste" police. You don't have to like everything but you also don't need to be critical of everything you disagree with.
And yes, this IS "Off Topic".
If we're talking about those little air compressors that run on 12 volts then it is quite likely being used to either inflate a flat tire or perhaps inflate pool toys. It's EXTREMELY unlikely anyone would ever think to use it for "Professional" work. Since it can take 30 minutes to inflate a small tire from flat to 32 PSI, in theory it would take four hours to pump up a small tank to 125 PSI. And that is IF it could manage to reach that much pressure. Ever. So I don't think we're talking about an industrial use for a pocket compressor.
MaxHeadRoom
Joined Jul 18, 2013
30,808
* Voltage: 12V DC
I assume it is a small 12v automotive type you plug into the cigar lighter socket?
If so the current will gradually increase as the tire pressure increases, so with nothing connected, it will be a lot lower than max current.
Using the car battery you will not see any voltage drop.
This is mine.
Audioguru again
Joined Oct 21, 2019
6,826
Last year used my 12V tire inflator in winter with the engine not running. Then the engine did not start with the almost dead 6 years old battery. I used the power supply from a printer to charge the battery overnight and the battery has been fine ever since.
I never thought that a tire inflator uses so much current. Of course, I will turn on the engine next time.
