+/-12dB Gain Audio Signal
Limzy
Joined Apr 26, 2019
22
I looked up what a Op-Amp does, but I think I am not quite ready to understand all of this, so I just wannted to ask you how to use an Op-Amp to get -/+12dB gain on my Audio Signal. A easy explaination/ circuit whould help me a lot. I wannt to gain my Audio Signal form my Pc. I want my selfbuild graphic eq to have a gain that is controlled by a Potentiometer. The Ic I used (LA3600) has an Op-Amp already build in.
I am kinda new to electronics and just doing it as a hobby :).
38,540
Below is the LTspice simulation of a circuit using a low-noise audio op amp that gives a ±12dB gain adjustment range by pot U2.
The simulation shows the gain for 0%, 50%, and 100% pot rotation.
Audioguru
Joined Dec 20, 2007
11,248
Why don't you use the parts values and pcb shown on the datasheet of the LA3600? It has maximum boost of +8dB to +12dB and a maximum cut of -8dB to -12dB at each of its 5 frequency bands.
Audioguru
Joined Dec 20, 2007
11,248
Cheap speakers must have a horrible frequency response to need +12dB or -12dB of equalization.
The speakers I built have a very smooth and flat frequency response and only small woofers need only some bass boost.
+12dB is 16 times the power (!) which can destroy a tweeter or ruin your hearing.
Limzy
Joined Apr 26, 2019
22
So what whould you recommend me to do when I want to use this with headphones?
I don't think 16 the Power whould be so healthy for headphones? Should I go for +/-6dB?
Limzy
Joined Apr 26, 2019
22
Schematic_La3600_Sheet-1_20190511142724.png This whould be my schematic. I won't use 20 pots but 10 stereo sliders 2 for every bands (left and right). I am thinking about not getting an other gain pot because I chould just use all the sliders a a gain. What are your thoughts about it? Maybe any suggestions to improve the design?
38,540
That likely will not give a flat frequency response with some humps between the set frequencies, but it may not be noticeable in the audio.
You might just be able to use a dual audio pot to reduce the gain, as the max (0dB) gain may be sufficient.
Limzy
Joined Apr 26, 2019
22
I if I understand you correctly I should just put a dual pot on the end and use it as just negative gain?
bertus
Joined Apr 5, 2008
22,940
In the datasheet there is a sample circuit with the frequency response:
As you can see, there are dips in the frequency response when the gain is max or min.
Audioguru
Joined Dec 20, 2007
11,248
How will you measure the frequency response of your speakers, headphones or hearing? Do you want a flat frequency response?
Or do you want to adjust the equalization so that a band sounds closer with a brighter sound or is farther with a duller sound?
Or do you want to make the sound different to what is recorded (more or less level at certain frequencies)?
Limzy
Joined Apr 26, 2019
22
It is just a "for fun and education" project I want simply use it with my headphones and without spending a lot of money get a certain thing that does exacly the thing I want, just a eq that can equalize certain frequencys and sounds decent.
I have got a other question. If I power it with micro usb and then a boot conveter to 12v, will it make a diffrence if I power it with just 5v. And how does the noise look like? Is it just depending on my usb adapter?
Audioguru
Joined Dec 20, 2007
11,248
Fiddling randomly with an audio equalizer without seeing the original and the new frequency response graphs on an oscilloscope is useless and can cause damage to your headphones and to your hearing (deafness).
I guess you did not see the datasheet for the LA3600. It says the recommended supply is 8V and a graph shows that it barely works with only 5V. If you boost frequency levels then you need to turn down the levels of the input so that the LA3600 output does not cause severe clipping distortion.
The LA3600 cannot drive most headphones but it can drive an audio amplifier or a headphones amplifier.
Noise could be high frequency hiss, mid frequency buzz or low frequency hum or any combination.
Limzy
Joined Apr 26, 2019
22
So you are saying I should just bumb it?
If so do you have a idea how I can realize this (different IC and so on)? Or is it just undoable?
Audioguru
Joined Dec 20, 2007
11,248
For speakers you need an audio power amplifier that produces as much power as you want. For headphones then you need a headphones amplifier. If your speakers or headphones have a horrible frequency response then fiddle with an equalizer that might make better sounds.
Limzy
Joined Apr 26, 2019
22
I don't need a Amplifier I want to build a eq.
Audioguru
Joined Dec 20, 2007
11,248
The EQ circuit cannot drive headphones, instead it drives a headphones amplifier which drives the headphones. The datasheet of the LA3600 shows it driving a 10 thousand ohms load. Your headphones are probably 32 ohms.
Limzy
Joined Apr 26, 2019
22
Couldn't I just decrease the amplification? My Headphones got 18 Ohms.
