120V 25A H-bridge circuit PCB
rfengineer28
Joined Apr 28, 2021
79
Hello, I am getting ready to do a pcb layout for the h-bridge configuration below which will serve to drive a brushed dc motor. This circuit is for my senior design and i would like to implement best practices to have a fully working circuit. My plan was to have a 4 layer board with a power plane at the top and a ground plane at the bottom and just connect all my low voltage traces in the 2nd and 3rd layer. I have been thinking about adding a bulk capacitor, but i am not sure if that would be necessary. I would appreciate any input, thanks.
ronsimpson
Joined Oct 7, 2019
4,777
Why are you not using a H-bridge Gate driver that drives two MOSFETs at a time?
I think an op-amp is not right to drive the bottom MOSFETs.
If the timing is hard, there are Gate Drivers with built in dead time.
I cannot talk about PCB design without knowing what the voltages and currents are.
Papabravo
Joined Feb 24, 2006
22,106
What provision have you made for deadtime in the switching signals? The last thing you want to happen is to have a short across the power supply.
I second @ronsimpson on using an opamp to drive a MOSFET gate. Definitely a suboptimal way to go.
LowQCab
Joined Nov 6, 2012
5,101
100ma is stout for an Op-Amp,
but it's not adequate to switch ~4nf of Gate Capacitance at high speeds.
BTW, a IXFH50N17 doesn't seem to exist, the closest thing seems to be a IXFH50N20,
and your Schematic does not include Voltages,
that Op-Amp drops at least 2-Volts off of the Supply, so keep that in mind.
What are You planning to use for Heat-Sinks ?
Where is the Power-Supply ?, that's one of the most important parts of the Circuit.
