120mA 17V MAX CC LED driver
smilem
Joined Jul 23, 2008
162
Factory specs on bulb:
3.5W
37mA
Measured specs with OEM PSU:
4.4W
32mA
128V
7Leds = 1Led => 32mA and 18.28V
Desired PSU
AC 230V to ~18V CC PSU autoranging and at 20-25mA all leds in parallel
smilem
Joined Jul 23, 2008
162
I hsve this PSU that uses JW1992M CC driver, the output current with connected LED's that are parallel is
14/15mA
13.5/14.2V
http://www.icdemi.com/manual/JW1992C.pdf
My PSU looks like this, but short circuit curent is 118mA
https://www.alibaba.com/product-det...pm=a2700.7724857.normalList.12.786f7fe1mVUTOl
I see I need to repalce the Current sense resistor and will have more current/voltage? But how to calculate it the datasheet is unclear, there is soldered 1R5 current sense resistor in PSU.
My question what to replace it with?
ronsimpson
Joined Oct 7, 2019
4,892
1: In the data sheet there is a "max" current based on how big the internal MOSFET is. There are versions of output MOSFET W, A, B ,C, D and how much current max. Do not get near the max current for the part in your board.
2: I can not find "Vref" so the formula will not work. But it is clear the current is related to 1/Resistor. So if you want 2x the current the resistor needs to be 1/2.
It looks like 0.8 ohms = 250mA based from information in post #5.
smilem
Joined Jul 23, 2008
162
Thank you or your input.
I used 4.7ohm and 1ohm resistor to make 0.8ohm
Now I get this output on my leds:
14.6V
36mA
It's interesting as I first tried 1.2ohm resistor and I got 15V 14.23mA
With 0.8Ohm I get 14.6V 36mA it's alittle low on the voltage for some reason, but miliamps are spot on.
My version is M
Any suggestions?
smilem
Joined Jul 23, 2008
162
I connected whole string of leds 7 total, and I don't know why but voltage is the same 14.6V but current is 36mA !
Why? Should be 36 x 7 = 252mA or at least 118mA ( short circuit curent is 118mA ).
Any ideas?
18,184
Any ideas?
Series or parallel? How are you measuring current?
smilem
Joined Jul 23, 2008
162
Leds are connected in Parallel current measured by uni-t ut210e clamp on 2A mode on one of the wires to leds.
ronsimpson
Joined Oct 7, 2019
4,892
I do not understand exactly what you are doing but:
I think you chose a resistor for 36mA. With one set of LEDs you get 36mA. With two sets of LEDs you should get 36mA total. With 3 set of LEDs you will get 36mA etc..... You built a 36mA power supply. It will make 36mA. It will not make 252mA.
18,184
Parallel is not a good idea unless you use load-balancing resistors. Otherwise one string will draw a little more, get hotter and draw still more, and potentially overload.
