12 volts overhead leds in trailer that switch on if either or both doors open
LEEQ
Joined Jul 5, 2024
23
Crutschow, I learned how a relay works from my work with the pid controller. The output from the pid to the relay was 5 volts, and that opened the full voltage. What I'm not clear on in your proposed circuit is where I'm getting low voltage (ie 5 volts) to run to the switches and relay in order to signal it to open the full 20 volts at the relay. I hope I'm being clear enough to understand. I'm very novice at this sort of thing. I appreciate the help
38,952
The battery is 20v. the buck converter steps it down to 12v. There are four, 20 watt leds.
Relays come in many different operating voltages, not just 5V.
So you would be switching the battery voltage to control the relay, but 20V is an odd battery voltage.
What kind of battery is it?
You could use a simple LM317 regulator to drop the 20V to the 12V coil relays I referenced.
dl324
Joined Mar 30, 2015
18,524
Check your LEDs to see if they're 20W equivalents or 20W actual.
A 60W equivalent LED bulb for a 120VAC light fixture actually dissipates more like 10W. It gives the same number of lumens as a 60W incandescent bulb, but isn't actually a 60W bulb.
LEEQ
Joined Jul 5, 2024
23
The leds are 12v flood lights for landscaping. I have used a buck converter with these and the dewalt battery to make portable jobsite lighting. I have used the same set up for trailer lighting with a simple on/off switch.
LEEQ
Joined Jul 5, 2024
23
Mr Chips, I don't have them yet. 12v 20 watt flood lights. they are basically a board with a bunch of 2835's on it backed by a heatsink/housing with a glass cover.
LEEQ
Joined Jul 5, 2024
23
Crutschow, I think I begin to understand what you are saying. Could you draw or describe the circuit including the lm317 to drop voltage for the 12v relay?
35,324
12V DC/AC 20W LED floodlight would be 20W consumed power, i.e. just under 2A @ 12V.
That translates to about 1.2A @ 20V.
LEEQ
Joined Jul 5, 2024
23
Definitely a bit more complicated than your original suggestion. I'm looking for switches that I could use to do it that way. In this more complicated version with the relay I would need help to know where to hook what wire on the relay, as well as calculating the resistor value.
sghioto
Joined Dec 31, 2017
8,765
12 volt relay coil is generally no more then 150ma so those .6 amp switches you listed would be fine.
One you select the relay it's a simple calculation to determine the resistor value.
BobTPH
Joined Jun 5, 2013
11,678
Using a buck regulator with an enable input gives you the best of both worlds. The switches need only carry the negligible leakage current of the enable input. No relay needed, minuscule draw when off.
LEEQ
Joined Jul 5, 2024
23
Would this way be better than the way you suggested first?
38,952
The connections are shown in post #30.
For a typical 12V auto coil current of 200mA, the resistor value would be about 40Ω, 3W.
LEEQ
Joined Jul 5, 2024
23
I ask because I found switches rated at .25amps at 125vdc. They are also rated at 5amps at 30vdc. I'm assuming they would be rated a bit higher amps at 20vdc than they were at 30vdc. Does this sound right?
