12 VOLT POWER SUPPLY
dougalere
Joined Mar 4, 2015
128
HI
just a quick query
ive just tested a 12 volt power supply, but its reading 19 volts with no load,safe to use?
i would have expected a few volts above, but that seems a lot.
thank you
dougal
dougalere
Joined Mar 4, 2015
128
hi bertus
its always worked fine,i was just going to use it to test someone elses hi value kit, so i thought id just check it first, im sure its ok.
dougal
Alec_t
Joined Sep 17, 2013
15,120
Whether it's safe or not would depend on what that kit is. Personally, I wouldn't risk it as is, especially on "someone else's high value kit". You could try driving a small load and see if that brings the volts down to a safer level.
Lestraveled
Joined May 19, 2014
1,946
My guess is that is unregulated. Under a 1 amp load you will get closer to 12 volts. So, depending on the load you will get between 19 and 12 volts. Read the data from the kit. If it draws close to 1 amp you are probably fine.
