12 Volt Lead Acid Battery Cutoff Circuit
coolyyz321
Joined Mar 17, 2017
90
I have a boombox that has a 12 volt lead acid battery as a backup battery, the thing is that I need a cutoff circuit that will cut off the battery from the circuit at 11.6 volts. What parts would I need to make this happen?
38,946
Below is the LTspice simulation of a circuit using a TL431 reference to provide an accurate and stable cutoff voltage.
When the voltage at the Ref pin drops below 2.5V, the TL431 stops conducting and the MOSFET is shut off, removing the load.
For the values of R2 and R3 shown, the cutoff is slightly below 11.6V.
R4 provides about 100mV 0f hysteresis so that the battery wouldn't be turned back on when its voltage slightly rises after the load is removed and oscillate around that point.
The P-MOSFET can be just about any standard (not logic-level) MOSFET with an ON-resistance of 100mΩ or less.
R_Boom-Box is the simulated load.
coolyyz321
Joined Mar 17, 2017
90
This circuit exactly how it is in the diagram will cutoff at 11.6 volts, correct?
Below is the LTspice simulation of a circuit using a TL431 reference to provide an accurate cutoff voltage.
38,946
For the R2 and R3 values shown the cutoff is nominally 11.56V.
You can make the cutoff voltage adjustable by changing R2 to a 50kΩ pot (wiper connected to one end of the pot to make it a variable resistor).
ian field
Joined Oct 27, 2012
6,536
You can get away with discharging to 10.8V without damage - but you don't want to leave it discharged that low more than a few days.
coolyyz321
Joined Mar 17, 2017
90
When I make this circuit, the circuit does not cuttoff at the right point, and acts like a dimmer when using a test led if that makes sense,as the voltage goes down the led gets dimmer and dimmer when connected to the NFET. it cuts off at 9 volts and turns back on at 3 volts, what in the world, could the TL431 be blown, or something else?
ronv
Joined Nov 12, 2008
3,770
PFET?
coolyyz321
Joined Mar 17, 2017
90
I used the NFET as an alternative, thinking it would worked. Could this only work with the PFET with that 1MEG resistor providing hysteresis so that the circuit wont turn on? I am new to PFETS, so I don't know much about these types of MOSFETS.
ronv
Joined Nov 12, 2008
3,770
Yes, It is for a PFET only. We can help you find one if you tell us how much current the load takes and where you are located. US. Europe, etc..
coolyyz321
Joined Mar 17, 2017
90
I go on a electrical component supplier called Farnell Element 14. I live in the US and the power draw is 6 to 7 amps maximum. Thank you for the help.
38,946
If you don't know much about them, then I'm puzzled why you would think an N-MOSFET would work in place of a P-MOSFET. o_O
That's likely never true in any practical circuit.
#12
Joined Nov 30, 2010
18,224
Let me try to give your thinking a boost. You can temporarily imagine an n-fet as an npn transistor and a p-fet as a pnp transistor to get the logic of the circuit correct. Then switch the active component back to a mosfet, correct for the difference in gate voltage and gate current, and then your circuit will work.;)
coolyyz321
Joined Mar 17, 2017
90
The cutoff circuit for some reason will not cutoff at that set voltage, and the circuit is exactly like in the diagram. What could be happening here.
38,946
Likely a wiring error
Show us the exact circuit you built with the voltages you measure at each circuit node.
