Mate of mine is a pilot.. was telling me how many of his mates plug their phone/iPad chargers etc into the airplanes cockpit power - 115v @ 400hz. Apparently, they work fine, no damage - BUT, they do get pretty hot/warm - this is the only noticeable side effect.
These little power supplies would be switch mode I'm sure - is that normal for phone/ipad chargers these days - ie no old style transformer - assuming it is.
So the question is.... what would be going on to generate the added heat.? (specifically) .. and, if you wanted to mod the power supply to be fine with 400hz (only, no longer 50/60) what would you change.?
* Not after advice or commentary about how bad this practice is etc etc - just after the engineering on what is going on - thanks for respecting that. *
