VERY interesting part, but $4 each for an LED is a lot.I found these https://www.pololu.com/product/2535,
Above you said that all of the channels will not have the same LED count. What are the largest and smallest number of LEDs in a channel?
ak
We are finalizing the layout Wednesday I will post then.VERY interesting part, but $4 each for an LED is a lot.
ak
That is for a 10 pack.VERY interesting part, but $4 each for an LED is a lot.
The pricing is for a 10 pack. If you select quantity 1 and add it to your cart, it shows 1 10 pack and a total of $4.95The ali express pricing is very good, but I disagree with your read of the Pololu pricing:
I think "unit price" means the price for 1 piece in any of the quantities listed. Makes sense to me, as I don't think the price would drop by 90% going from 1 to 10 pieces at a high-markup specialty site.
ak
BobThe pricing is for a 10 pack. If you select quantity 1 and add it to your cart, it shows 1 10 pack and a total of $4.95
Bob
A couple of things.I have very limited experience with addressable LEDs, but I've generally had good luck with advice from adafruit, and their guides raise some concerns when dealing with 1000 LEDs.
- At least when using their library, each LED requires 3kb of RAM, meaning this project would require 3kb of RAM just for the LEDs (50% more RAM than an Arduino Uno.) Some Arduino models have much more memory than others, and you may find a library that requires less RAM per LED than theirs, but it's something to be aware of.
- They say the data lines are vulnerable to a few different things, and that a series resistor is needed at the first LED (easy) and also that a capacitor should be wired in parallel with the + and - legs of EVERY LED when using the through-hole 5mm variety (hard!) Not sure why it's recommended there and not on the strips, but that's what they say...
Thanks for the clarification. I'm bad at low-level (or even "medium" level!) programming and still lean heavily on libraries. I suspected there would be a better way than the 3byte/LED memory requirement, but since one of the "easy" implementations has that requirement and the thread starter has less Arduino experience than me, thought it was worth bringing up. I'm glad to know it's not a significant problem.A couple of things.
You do not necessarily need to use 3 Bytes for each LED. If you can determine, in the loop, what color each LED is with a few instructions, you do not need any storage at all. You simply write a loop that puts out the bits for each LED. For this application, each LED is one of two colors (on or off) and a range of numbers will tell which ones are on and which are off, so it is two comparisons to determine which color to put out. This is entirely doable without any storage per LED.
The capacitors are already on the strips. I tried removing a single LED from a strip and wiring it without a capacitor and it did not work reliably. Putting a 100nF across the + and - fixed it.
I have made many projects using strips and I never used a series resistor, and they worked reliably.
Bob
3b/LED, not 3kb/LED3kb/LED memory requirement
They can be updated at 800000 bits per second. With 24 bits per LED, that is 33,333 LEDs per second. So, unless you have more tha 333 LEDs on your hula hoop, it can be updated plenty fast (100 times per second.)I'm playing with some WS2812 LEDs in strips at the moment. My daughter wants a Hula Hoop for a show she is in. So far I have an accelerometer to sense the position but the LEDs may not be fast enough.
MisterBill2I recommend using a PLC to control the lights because an arduino is just a toy without any good mechanism to create an adequate package. AND, I recommend that the PLC be one that comes with the free programming software, which saves a lot of money and prevents a lot of grief. You will need output modules with relay contacts rather than transistor outputs. Or, it may be that you will need power relays, depending on how much current the LEDs in each channel draw. That is a big unknown at this point.
Ladder logic will allow a wide variety of options, and it is easy to understand, thus my recommendation.
I do, in fact, have a suggestion, which is a distribution company called "Automation Direct." Aside from a large line of PLC products, the programming software is readily available and free, and it runs on a PC. And they have a wide range of models, some are quite cheap.MisterBill2
Point well taken. I am selling the project and I don't want to own it.
I have not made a decision on lights so current usage is still a unknown.
Small PLC would be a better choice. I googled this up.
http://velocio.net/?gclid=EAIaIQobChMIzK7irbK32wIVFLbACh17vwMlEAMYASAAEgIpOPD_BwE
Do you have a suggestion for hardware?
Is there a distributor in the US that can help me with the wiring a programing?Use DMX dimmers.
Then you don't need to be an expert programmer, mess with Arduino's, MOSFETS, and all the rest.
https://www.alibaba.com/product-det...tml?spm=a2700.7724857.main07.3.2bcb656aMPFzsZ
Most of the PLC products from the source that I mentioned have FREE programming software available for download. You will need enough computer skills to install the software on your computer, though. Much of their product line also includes technical support service as well.. An added benefit is that they provide quite rapid product shipment, unless you owe them from previous purchases.Is there a distributor in the US that can help me with the wiring a programing?
