I've started building a wind generator. I've crafted myself 2 wooden blades for testing. Blades are 55cm long and at the base 10cm wide. Weighs about 300 grams including centre hub. I've found a source (windynation) stating that, with blades of that size, a 10mph wind could spin the blades at 400ish rpm under load (max 500watt).
Now I have this electric scooter engine, 24v DC, 150 watts, 2500rpm. It would be nice to get 80 watts into my 24v battery system. I have a 1/5 gearing ratio with the belt from the scooter to the wheel, so getting the rpm's shouldn't be that much of a problem.
My issue is : how to regulate the voltage for battery charging? I get the dump loads(preventing free spinning generator). But I often see just the generator connected to the batteries with a simple diode.The generators voltage will be pulled down to that of the battery, so that's ok as long as you have overcharge protection. My generator outputs 3-26v, and I need 28v to charge the batteries, I'll need a step up converter that's capable of efficiently converting a variable input voltage to 28v. I could use an arduino for pwm, use that to drive the boost converter to a stable 27,4v output voltage.
Or: don't mind the pwm modifcation, just boost the signal high enough (+27v) that it'll charge the batteries. My gut says it's not the best idea to feed higher charging voltages than necessary into a battery, but then they're lead acid, so they can take a beating.
