10 MHZ Time Base Revisited
Deleted member 115935
Joined Dec 31, 1969
There is your problem then,
10 MHz is viewed as a low frequency now days , when done on a PCB
Those no solder bread boards, are very high inductance / capacitance.
and if anything apart from new, the resistance of a contact is very very variable.
An oscillator is a very analog thing,
It has very high gain, and the phase shift is critical.
I'd imagine just putting your finger near the crystal up on those long wires will start / stop the oscillation.
If you want to make your own, put you oscillator on a bit of copper board,
mount the parts up side down, pins in the air, and keep wires SHORT.
with a decoupling capacitor on the board, and then send the clock to the solderless board.
You also seem to have a complete absence of decoupling capacitors,
you need 100 nf capacitors on each and every power pin to ground,
What's happening is all the noise from the buffers / counters on the PSU is being transmitted over all the wires, and being picked up by the oscillator wires.
radioshack5209
Joined Nov 25, 2020
68
Hi:
I just ordered an oscillator module and some 0.1uF polyester caps for decoupling. Should be here in a week or so. I am just getting back into electronics after a very long absence so I am still having to stock some parts.
Joined Dec 31, 1969
Hi:
Polyester 100nf,
ceramic would be normal and much better,
especially if you use X7 type,
dl324
Joined Mar 30, 2015
18,524
FWIW, I breadboarded a 10MHz oscillator using 74AC14.
Measurement taken with a 200MHz Tek scope and 100MHz probe.
I used 74AC14 because it's fastest CMOS I had and cut the leads on the resistor and capacitor to be as short as possible; left the crystal leads long.
This was from the output of the inverter. Buffering with another inverter didn't make much improvement. 0V is the bottom of the graticule.
Output from a 10MHz TTL crystal oscillator looks similar.
I didn't bother breadboarding the OP's circuit because I didn't have any HC gates handy.
Joined Dec 31, 1969
It's common for power supplies to not be shown. It removes unnecessary clutter. OP specified in post #3.
Your schematic doesn't show supply voltage either...
To be fair to @dl324,
There "schematic" is evidently a LTspice simulation, which as you say does not include the power, I don't know how you would show the power in LTspice,
Where as the OP, had a hand drawn schematic, and we were asking about the circuit, trying to tease out how the oscillator was built, so in that case the decoupling was critical to the actual design.
Joined Dec 31, 1969
View attachment 226299View attachment 226300View attachment 226301
OP, Please look at @dl324 circuit, and how small they have made the wires, how tight the circuit is.
Also look at how they have a capacitor to ground and a much higher resistor value,
See how hard it is, even when experts like @dl324 do it, it works , but only just ,
Bottom line, don't use solderless bread boards for analogue circuits.
Joined Dec 31, 1969
This might be off topic, so I've put in a new post, so it can be killed by mods if they want,
This thread is based around analog on a solderless board.
I'm old, to my generation, there was IMHO , only one expert in analog
Bob Pease
https://www.electronicdesign.com/home/contact/21809514/bob-pease
He had a great way of building I MUST SAY PROTOTYPE
analog circuits on copper clad board, with the parts mounted up side down,
1609411609707.pngIts all about knowing what you can get away with and cant,
which I m sorry only comes with experience.
dl324
Joined Mar 30, 2015
18,524
But wait... There's more...
I must have known this at one time, but forgot that BW specification for combo 1X/10X probes is for the 10X setting. When you operate at 1X, the probe conductor is a lossy wire and has a resistance of about several hundred ohms and the impedance of input capacitor on the scope can be relatively low (on the order of 1k at 10MHz).
That's what gives the "terrible" waveform I saw.
The signal with the 10X setting has a lot of ringing due to the inductance of the scope probe ground clip. I'll work on determining what dampening resistor to use to dampen the worst of the oscillations and post pictures with a 10X probe.
I also learned that for Tektronix probes, the specified probe bandwidth is for the overall "system" when used with an appropriate Tek scope. So I'll dig out a Tek probe. I usually use "cheap" probes, so a 10X 100MHz probe will be -3dB at 100MHz which is combined with any BW limitations of the scope. And much worse on 1X.
dl324
Joined Mar 30, 2015
18,524
When I was an R&D tech at a well known company, almost all of my prototypes were done using that style. I soldered BNC connectors by points I wanted to probe and angled them so that I could use the shortest wire possible to connect to the net.
I also made use of the coil of wire that goes on the ground at the probe tip to cut down on inductance.
That reminds me of a 100MHz optical scope [probe] prototype I worked on. Wish I had one now...
EDIT: added probe in the last line.
dl324
Joined Mar 30, 2015
18,524
And we don't know what technology the inverters are. I assume they'd be HC because that's what the OP was using, but that's just an assumption.
I don't think I've ever been able to run LTspice without a ground symbol in the schematic. But don't use LTspice much and I've never tried to do a simulation with digital logic...
dl324
Joined Mar 30, 2015
18,524
Here are the waveforms with 10X probes.
Tek P6105 100MHz 10X (only):
Generic Chinese P6100 100MHz 10X:
Ground is the bottom of the graticule. Both sets of pictures are at 1V/div vertical sensitivity (Tek 10X probes change the displayed voltage on compatible scopes to be correct). Dampening with with a 150 ohm resistor using the standard 4-5" long ground lead. 7704A scope bandwidth is limited to 200MHz by the 7A26 vertical amplifier.
MIS42N
Joined Jan 25, 2013
22
I have never built a crystal oscillator, only read about them. One thing I read was for best results have some way of limiting the drive so they are not stressed. Is it possible the oscillator is stressed? For 10MHz I bought several OSC5A2B02 second hand OCXO off ebay. With a stable voltage supply and a method of varying the control voltage they can be pulled to +- 1Hz reliably.
Joined Dec 31, 1969
@MIS42N
Not heard about over stressing an output,
oscillators such as wien bridges,
https://en.wikipedia.org/wiki/Wien_bridge_oscillator
have a feed back circuit , which limits the amplitude
These TTL oscillators are fairly self limiting, provided you don't over load the output.
But as you did,
the cost of crystals and the components needed are normally more than a self contained oscillator as you have found,
Even in the commercial world,
its In my experience, its getting to where we dont use crystals, but oscillators.
Given that crystal oscillators are temperamental, there is a cost for each part placed on a board, and that the difference in cost between oscillators and crystals with bits is effectively zero, the cost of even one board in 1000 not working due to a crystal not working is more than any possible savings in crystal costs.
radioshack5209
Joined Nov 25, 2020
68
Hi Andrew & Dennis:
I got my 10 MHZ Saronix NCT050C oscillator module. It works okay. Attached is the output waveform
although it is not that square. The output voltage is 4.28 vpp. Running the output through a 74LS04
makes no difference.
Here is the 10 HZ output from the divider chain. The output voltage is 3.60 vpp.
dl324
Joined Mar 30, 2015
18,524
You have ringing caused by the fast edges and the parasitic inductance in your scope probe. The voltages you're reading won't be accurate until you dampen the oscillations. You can dampen by adding a small resistance in series with the probe. In my case, 150 ohms dampened the worst of the oscillations.
radioshack5209
Joined Nov 25, 2020
68
Thanks Dennis.
I found that on my scope a 470Ω resistor eliminates much of the ringing as attached.
The next thing that I want to do is to design a circuit to control the gating. I will post a circuit that I
am working on soon.
