10 MHZ Time Base Revisited
radioshack5209
Joined Nov 25, 2020
68
I have a 10 MHZ time base circuit (see attached). It goes through a chain of 74LS90s to divide it down to 1 Hz.
It count up to 99999 just fine. When probed with my scope, I get messages such as "Sine Wave Detected on Ch1",
"DC Level Detected on Ch1", "Unknown Signal on Ch1" and sometimes "Square Wave or Pulse Detected on Ch1".
If I feed a 10 MHZ square wave into the counter chain with my function generator, there is a good clean square
when various points are probed.
Any suggestions would be appreciated.
dl324
Joined Mar 30, 2015
18,479
"DC Level Detected on Ch1" and sometimes "Square Wave or Pulse Detected on Ch1". Any suggestions would be
appreciated.
Where are you probing? What is the supply voltage? What is the scope bandwidth? Are you using a 10X probe? Has the probe been compensated?
Circuit in question:
radioshack5209
Joined Nov 25, 2020
68
Hi Dennis
probing the time base output and various points in divider chain
5 volt supply
scope bandwidth is 50 MHZ
Tektronix TPP0051 10X passive probe
Length:1.3m
Applications:Low-frequency measurements, Low-frequency computer and telecom measurements, Power supplies, Low-frequency amplifiers
Attenuation:10X
Bandwidth:50MHz
For Use With:BNC oscilloscopes with 1 MΩ/20 pF inputs.
Input C in pF:<12 pF
Input R in Ohms:10 MΩ ±1.5%
Input Voltage:300 VRMS CAT II
Risetime:<7 ns
Deleted member 115935
Joined Dec 31, 1969
Can you share a picture of the actual parts unit please.
Oscillators are incredibly sensitive to how they are wired up,
the difference between one oscillating and one not can be just how a wire is placed,
What actual traces do you get on the scope ?
dl324
Joined Mar 30, 2015
18,479
Your scope will only display the third harmonic well (the 5th will be 3dB down), so the corners will be rounded but it should still be more like a square wave than a sine wave.
Has the probe been compensated? The probe is also 50MHz, so it will give another 3dB attenuation at 50MHz.
Pictures of the waveform and messages would be helpful.
michael8
Joined Jan 11, 2015
472
That schematic doesn't show the supply voltage.
Nor does it show where you are probing the circuit.
The 74HC04 output driving the crystal will presumably be
full gnd to Vdd which seems excessive for the crystal.
Also the 4.4K (two 2.2K resistors) across the crystal
isn't the environment the crystal needs for best
response.
I'd guess that you've actually built this:
radioshack5209
Joined Nov 25, 2020
68
The messages are:
"Sine Wave Detected on Ch1", "Unknown Signal on Ch1", "DC Level Detected on Ch1" and sometimes
When the message says square wave, the display shows a decent wave form with slightly
rounded corners. When any of the other messages appear, the wave form is a squiggly
line with lots of noise.
The probe is compensated.
I am wondering if the oscillator circuit is no good because a 10 MHZ square wave
from my arbitrary function generator results in perfect wave forms no matter where I place
the probe.
Joined Dec 31, 1969
You need to show us your actual circuit ,
preferably with the scope probes attached, and a picture of the scope trace,
I'm sorry , but the error messages tell us very little,
a wiggly line, will tell us something,
Im also concerned about your circuit,
when I have made TTL based crystal oscillators, I have some capacitors in there, and the resistor is of the order of many M ohm,
e.g. https://www.electronics-tutorials.ws/oscillator/crystal.html
Your circuit also seems to have the crystal connected across a buffer, not an inverter,
this is more similar to your circuit, ( circuit 1d)
but note the capacitor in the middle
https://www.analog.com/media/en/technical-documentation/application-notes/an12fa.pdf
dl324
Joined Mar 30, 2015
18,479
You need to show us the waveforms that correspond to the messages. If it isn't clear, we also need to know the vertical sensitivity setting.
the probe.
Your function generator has more drive capability than a 74HC gate. Your oscillator circuit might be on the verge of instability and works when there's no extra loading, but adding the probe affects it. It would be informative to know what happens to the output when you get the questionable waveforms and messages.
radioshack5209
Joined Nov 25, 2020
68
The output drops when I probe the output.
How can I increase the drive of the oscillator?
radioshack5209
Joined Nov 25, 2020
68
Its driving seven 74LS90s in a divider chain to get to 1 HZ and five 74LS90 / 74LS375 / 74LS47 counter/display stages and a dual 74LS123 that will control the store data, counter reset, and a 74LS14 for the power-up logic.
dl324
Joined Mar 30, 2015
18,479
What is the HC14 actually driving? It can only be driving one of the LS90's.
Joined Dec 31, 1969
The output of the HC14 shouldn't be loaded by your scope probe. What is it driving?
If you have spare gates in the 74HC14 package, you can put some in parallel with the existing gate. This isn't recommended if the gates aren't in the same package.
BIG NOTE:
paralleling outputs in same package is a good answer to increase drive,
BUT, you scope, assuming its has a probe , is NOT going to load the output of the 74HC14 to an extent that you would notice,
So paralleling up the gates is MASKING the REAL PROBLEM, making it harder for you to find it.
Find and fix the problem.
Second up, you have not provided actual pictures of the setup, this is most likely the reason for the problem,
Third, you are now asking about off the shelf oscillators,
If you don't want to make your own, then a much cheaper and reliable option is an off the shelf 10 MHz TTL oscillator.
almost no one makes there own 10 MHz oscillator now days.
If you want through hole,
an example
https://www.digikey.co.uk/product-detail/en/epson/SG-531P-10-0000MC-ROHS/SER1208-ND/1021904
or SMD, an example
https://www.digikey.co.uk/product-detail/en/ecs-inc/ECS-5032MV-100-BN-TR/XC3097CT-ND/9953277
or if you want REAL stability
https://www.digikey.co.uk/products/...t=1000011&page=1&nstock=1&rohs=1&pageSize=500
( just joking, just to show you what's around )
radioshack5209
Joined Nov 25, 2020
68
BIG NOTE:
an example
or SMD, an example
https://www.digikey.co.uk/products/en/crystals-oscillators-resonators/oscillators/172?k=oscilator&k=&pkeyword=oscilator&sv=0&pv183=316150&sf=0&FV=69|411897,mu10MHz|2150|0,mu10MHz|2150|1,-8|172&quantity=&ColumnSort=1000011&page=1&nstock=1&rohs=1&pageSize=500
Here is my freq ref circuit and counter chain.
