0-99 Counter Circuit :)
DXJohnPaulXD
Joined Jun 8, 2016
23
Hello guys my name is John Paul, do guys have any idea how to make a 0-99 up/down counter with a common cathode display?
also can you tell me guys where to put a schmitt trigger to prevent button bouncing?
i cant find a 0-99 counter using IC 4510 and 4511 or IC 7490 and 7447
i want it to count up and down using a button ;)
and i cant find any simple schmitt trigger circuit :(
Any Help would be very Appreciated :)
ScottWang
Joined Aug 23, 2012
7,504
Add an cmos TLC555 set to the monostable to be the debounce component, the delay time setup as 50mS, the pin 3 connect to the clock input of CD4510.
hp1729
Joined Nov 23, 2015
2,304
Something like this? I haven't built it yet but it should work.
DXJohnPaulXD
Joined Jun 8, 2016
23
Wait a minute. Did your circuit say to use the 4510 IC to be schmitt trigger?
If 4510 ic is the schmitt trigger then how do i connect it?
Show the pic of ur design on breadboard ;)
I forgot to say im a 10 yr old kid lol
DXJohnPaulXD
Joined Jun 8, 2016
23
UPDATE: it was a cd40106 ic (my eyes betrayed me) when i looked at its datasheet it was made out of schmitt symbols (schmitt trigger?) but i found another ic called 74hc14....so maybe i can subsitute the CD40106 with a 74HC14?
Even if one of them is an inverted schmitt trigger
ScottWang
Joined Aug 23, 2012
7,504
How wonderful a 10 years old kid joined the forum, really welcome... :)
And you preferred the 14 pins ic then a 8 pin cmos TLC555, you like big size?
dl324
Joined Mar 30, 2015
18,439
Didn't realize you were only 10; not many children can read schematics and datasheets:)
Here's a schematic using CD4510 and CD4511. I just drew it and haven't tested, but it should work.
Post here if you have issues or questions.
dl324
Joined Mar 30, 2015
18,439
so maybe i can subsitute the CD40106 with a 74HC14? Even if one of them is an inverted schmitt trigger
They're both schmitt inverters and logically equivalent, but CD parts can operate from 3-15V while 74HC operate from 2-6V.
There are many different 74 series hex schmitt inverters: 7414, 74LS14, 74HC14, 74HCT14, 74AC14, 74ACT, ... They differ in supply voltage, speed, fanout, input/out characteristics.
DXJohnPaulXD
Joined Jun 8, 2016
23
Tlc555 is not available in the store so i chose the other one ;)
EDIT: Im gonna use the NE555 timer instead of the tlc555 is that ok?
DXJohnPaulXD
Joined Jun 8, 2016
23
Oh ok then i will choose cd40106 tnx ;)
