Most 3-terminal regulator appnotes show how to add an external pass transistor to boost the current.What's purpose of the power supply?
0 ~30V.
Or using LM317 plus 2N3055 to increasing the current, it's easy to get the schematic from google.
I gave this some thought and think a simple tracking, switching preregulator is probably the best way to go. This will also lower dissipation in the LM317 to a few watts max.Center tap to either winding is 35ish volts. Would that be a problem?
I suspected this, which is why I asked about it in post #13.Secondary winding puts out 73v. Center tap to either winding is 35ish volts.
Using resistors to drop the voltage isn't practical. At low current, you wouldn't have enough drop. At high current, you'll have a lot of power dissipation in the resistors.So as for the high voltage problem. What can be done about with lets just assume no extra parts beside some spare parts. I do have high wattage resistors. Do you think it would be fine to add a high wattage in series with the transformer primary? I'm thinking say a 39ohm in series would drop the secondary a bit. I may have a lower ohm.
363 ohms will give you 5.8V max on the 6V range.They didn't have a 390ohm resistor so I got 330 and 33phm resistors.
I know where you're coming from. I'm at least 30 minutes away from just about everything... But it's very quiet where I live.Cheyenne is a 45 minutes drive from my house and Laramie 20-30 minutes.
In the primary, those resistors are dissipating a total of 20W; they're undersized. If you're going to do that, and I don't recommend it, put them in the secondary where they'll dissipate a third of the power and still drop the voltage.So a 680ohm 5watt and a 12ohm 5w in series get my secondary to 31.5vac. Now I'm rolling! The 680ohm was burning hot which led me to put the 12 and 680 in series. 10watts total.
If you use my preregulator idea to drop the voltage differential on the LM317 so it will dissipate 3W max, you could probably use a TO-220 heatsink and not have to worry about isolation.So with the lm317, since the output and heat sink are together what can I do? I don't have any heat sink insulating pad things.
I recommend always grounding the case.And I wanted this case to have a new 3 prong grounded case. Shall I just not ground it then?
It appears in the photos in post #1 that the heatsink isn't isolated from the case (which should be grounded if a 3 prong cord is used).You don't need insulation as long as the heatsink is not touching anything in the circuit.
As for the dropping resistors that's weird. No matter the ohms law math I do it doesn't have the right numbers. The transformer draws 60ma. At a total resistance of 726ohms including dropping at 123v. Nothing is right! Going to check that out a little more in the morning with my watt meter. I made a little start on the circuit board. Got two potentiometers in place. One for the meter the other at 385ohm(the closest I could get). I had to use one of my 0.1uf 630v orange drops in this. And then a 68ohm plus a 15ohm in series to get as close as possible to 85ohms. Well I'll finish working tomorrow. I'll have to find a power cord for this. Still need to understand that lm317 and its heat sink so I don't blow something.In the primary, those resistors are dissipating a total of 20W; they're undersized. If you're going to do that, and I don't recommend it, put them in the secondary where they'll dissipate a third of the power and still drop the voltage.
Use the power equations: P=V*V/R=120*120/726=19.8W; with most of it dropped by the 680 ohm resistor (18.6W).As for the dropping resistors that's weird. No matter the ohms law math I do it doesn't have the right numbers. The transformer draws 60ma. At a total resistance of 726ohms including dropping at 123v. Nothing is right!
