I don't think the transformer will give enough current. I can try but I don't want to damage it. As for the lm317/350 I thought as i don't plan on drawing a large current the lm350 would fair better without me having to worry about my heat sink being perfect. I kinda plan on using the original metal piece that separated half the Eico case as the heat sink. Otherwise buying a large heat sink just for would be more money and more wasted space. As for using two pots I can see if maybe my one 2k is ok. I'm not sure as it sure has sparked a lot in there. That could maybe allow me to do a 2k resistor in parallel with one. I'm thinking that would then be 1k and adjusting the pot would give me between 0 and 1kohms. Correct me if I'm wrong. And I have plenty of dpdt and multipostion switches to use. Pulled them from a broken oscilloscope.
