zener diode help
Status
Not open for further replies.
outlander800r
Joined May 29, 2014
Hey guys im not that savy on using diodes.. and need some help.. i have a 2013 canam maverick 1000.. in high gear there is a sport mod that gives you 100 % throttle.. in low gear you do not have this option and is limited to 40 %.. however on the transmission connector for low gear there are 3 wires.. a 5v wire a signal to ecu wire and a ground.. there is a guy saying i can take a jumper wire from the 5v wire to the ground with a .5 watt 3.3v zener diode and that will trick the ecu into thinking its in high gear.. and the voltage for high gear is 3.3 v... any help if this would work would be greatly appericiated.. thanks
bertus
Joined Apr 5, 2008
22,276
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
There will be enough sites where automotive questions can be discussed :
Member selected automotive forums
Bertus
Status
