So I know, based on the knowledge shared on this site, that bypass caps need to be included on all Power Supplies for IC's.
But, if you will take a look at the circuits I have included, I am not sure if I need them (only referring to the 555's). The reason I am unsure is that all of the 555's are either getting voltage supplied through the arduino or the other 555.
Thanks in advance for your input.
